20 Most Recent
Kenmore 19110 Computerized Sewing Machine Questions & Answers
How align a needle
Providing the flat side of the needle faces back you should not have any problems
Do I need to oil my Janome 525S sewing machine?
if you have a instruction manual look in it for oiling instructions and if you don't have a manual or it doesn't say anything about oiling,, then go to the website of janome and contact their customer service and ask them if you can oil the machine.. some machine can be oiled and some can not..
Code Lo
Betcha there is a small battery inside that helps maintain the computer's ROM. Since this is a sears machine call Sears/Kenmore parts and see what they can offer you in the way of help.
Acquired a used Kenmore 158.1792 model sewing
Sounds like a tension problem. Do you have a manual ?? If not, they're available online for $5 to $10 as a PDF problem. You'll want to check the top tension, and the lower bobbin assembly. [ I've got one of these machines, and used it for many years, although sadly it now has a burnt-out motor, and the motors are difficult/impossible to find ]
I'm trying to sew my first buttonhole. It
Make sure you pull down the buttonhole lever from the underside of the machine (near
where the needle threader is) If you don't do this, the machine will
make a few stitches and then stop. with error 6L.
thanks for using fixya.
I have a Kenmore 19110600 that was just purchased
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
I can't get my kenmore
BL error means buttonhole lever.This means your machines button hole lever is not pulled down.Or its loose.Check this lever and pull down.This should help.Thanks.Helpmech.
