20 Most Recent Dewalt 12V XRP Battery Pack Questions & Answers
Bad Battery pack, check voltage, try jumping nickel/cadmium battery with car charger, then put on charger.
Dewalt 12V XRP... | Answered on Aug 14, 2015
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Dewalt 12V XRP... | Answered on Mar 24, 2011
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
Juraj
Dewalt 12V XRP... | Answered on Dec 31, 2010
Needed -2 pair of adjustable pliers.
Hold the chuck with one pair, hold the hand chuck with the other pair turn in opposite directions to loosen bit.
Take care not to mar the plastic on the chuck.
Dewalt 12V XRP... | Answered on Dec 24, 2010
battery is bad and needs to be replaced. But first you might try and clean the contacts.
Dewalt 12V XRP... | Answered on Aug 09, 2010
Try placing the battery in a freezer for six hours before trying to charge the battery and if this doesn't work find a friend with a working charger and make sure using that method that you don't just have a bad charger.
Dewalt 12V XRP... | Answered on Jul 24, 2010
you can tell me address Dewalt at Germany!
Dewalt 12V XRP... | Answered on Dec 23, 2009
You can try warranty services. However, if they are having an event in your area you might just try going down there. I have taken bad batteries to them in the past and they just GAVE me a new one.
http://dewalt.com/events.aspx
Dewalt Drills | Answered on Oct 31, 2019
OPEN CHUCK FULLY AND LOOK INSIDE , THERE IS A SC REW YOU NEED TO REMOVE USUALLY A LEFT HAND THREADED ONE
Dewalt Drills | Answered on Sep 06, 2019
What kind of batteries are they? If they are NiMh and haven't been used for a while, they can lose their charge and NOT be sble to be charged again!
Do you have a 3rd battery that does work? Buy a battery to make sure the charger is working or that the drill is working. If yes to both of these, then your old batteries are NFG.
Dewalt Drills | Answered on Aug 18, 2019
As far as a schematic goes, I would guess that it is proprietary in nature and that not even dewalt "repairs" them. I wouldn't be at all surprised if the same model had several different versions of circuit boards representing different production runs
Dewalt Drills | Answered on Jul 01, 2019
  • Defective battery
  • Defective charger
Dewalt Drills | Answered on Jun 27, 2019
Check battery. put a new in and works?
Dewalt Drills | Answered on May 31, 2019
Dewalt 12V XRP Battery Pack  Logo
15 questions posted
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
holding battery charge 12v dewalt
  • Drills
