20 Most Recent
Fender CD140sce Acoustic Electric Guitar Questions & Answers
Battery
the battery is inside the sound hole take a mirror and look inside battery should be in a clip on the side of the module control
When I plug the guitar
If the mixer is receiving signal, then the problem is pilot error at the mixer, not the guitar. You did not mention what type of mixer you have so I have no way of helping. Common problems would be failure to send the guitar channel to the mixing buss, leaving the channel muted... but we really need the mixer and model number to give more help that that.
I am re-stringing my Fender
It is a little tricky, but you have to kind of pre-form the ball end of the string so it tucks under the ledge of the hole it goes into. Then put peg in and as you do pull up on the string slightly so the pre-formed ball end is caught under the ledge. Make sure the slot is toward the neck direction and the string seats in it, Also once the string is seated, kind of preform the string over the edge of the hole as the string is started to be tightened.
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM •
Fender Music
Answered
on Dec 15, 2023
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience.
I recommend the Fender single button footswitch for this use - Type: Footswitch
Number of Footswitch Buttons: 1
Manufacturer Part Number: 0994052000
It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
11/22/2022 1:29:51 PM •
Fender Music
Answered
on Nov 22, 2022
Guitar amp input not working
Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
4/17/2022 3:41:52 PM •
Fender Music
Answered
on Apr 17, 2022
