20 Most Recent
Dean Evo Xm Electric Guitar Natural Mahogany Questions & Answers
Ground wire is not attached
okay. the ground needs to travel through all your components.you have the -input jack, - vol. & tone pots, the -switch & all - pick ups. All should meet at the body ground. Usually there is a wire that comes from the saddle, through the guitar, and enters somewhere in the access in back. (remove the plate that cover your vol. and tone pots). Good Luck
I did not get a
I don't know precisely, but since it is a dual humbucker and only has 1 switch and 2 knos, the knob nearest the neck is probably the volume, and the other is the tone. The switch should select which pickup is in use, towards the neck for the neck or rythym pickup, and the other way for the bridge or lead pickup. If it has a centre click position, that will be both pickups on together. If one of the knobs has a pull position, that will likely be a single coil switch for the lead pickup.
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
