20 Most Recent Nintendo Wii Fit for Wii Questions & Answers
The corroded batteries may have damaged the unit.
Nintendo Wii Fit... | Answered on Jan 30, 2018
I think waiting until your goal time is up, than taking a fitness test, I think that you can change your weight/BMI goal during the fitness test.
Nintendo Wii Fit... | Answered on Mar 25, 2016
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Nintendo Wii Fit... | Answered on Nov 05, 2015
You can use rubbing alcohol. If the disk is scratched some video rental places will fix it for a fee. You can also get a disk cleaner/ scratch remover device. There are cheaper ones but it gives you an idea of what to look for.
Nintendo Wii Fit... | Answered on Oct 12, 2015
There's no straightforward way, but thee are some workarounds, like changing the date to the deadline, etc.
The easiest workaround, I think, is to force your wii into thinking you've made the deadline early. I put in that I wanted to gain, instead of loose, 2 lbs, so I'm going to fake out the wee into thinking I've gained that 2 lbs already, by either holding something that weighs an additional 2 lbs or adjusting the clothing weight to compensate.
Once the wii registers that I've passed the goal and allows me to make a new goal, I'll re-do my body test with my regular weight. My faked weight will be erased, but my new goal will remain.
Nintendo Wii Fit... | Answered on May 12, 2015
They are just two different versions of the Fit game. The actual Wii Fit device is the same. If you already have a Wii Fit, you can buy Wii Fit Plus as a stand-alone game without the device. The Plus has some newer exercises.
Nintendo Wii Fit... | Answered on Apr 03, 2015
Check the Wii Fit discs region.If your Wii is USA(NTSC) can't read Europe(PAL) discs or back.
Nintendo Wii Fit... | Answered on Mar 29, 2015
Are you inserting the disc properly? And when is the last time you ran a laser lens cleaner through your Wii system. Dust and contaminants can cause disc read errors.
In the front. Its behind a small door above the disk slot or next to it if you have it standing on its side.
Nintendo Wii Fit... | Answered on Dec 18, 2014
This is a common problem. To fix this issue, you need to reseat the stress sensor.
Remove the foot from each corner using a normal Phillips Screwdriver.
- (keep them in the right order to put back later)
- Loosen (remove) the "stress sensors" small metal plate you see now at each corner using a "torx" screw driver.
- Re-seat the small metal plate by putting it back but don't screw too tight.
- Put the foot back on.
Hope this helps!
Nintendo Wii Fit... | Answered on Sep 08, 2014
 Are you pointing at the calendar with the wii remote? Other than that... you might want to try re-syncing the remote with the wii, or change the batteries in it. If none of that works, try cleaning the disc, a tiny bit of dish soap and a dribble of water should do the trick.
If all fails, something in wrong with the disc or the remote.
Nintendo Wii Fit... | Answered on Jul 18, 2014
Ok, I know you have said that you have done the syncing thing but please try it in this order -
1. Insert your Wii Fit disc and start the game
2. Press the Sync button on the board
3. Press the Sync button on the console after you have pressed the board Sync button (not both at the same time)
Hopefully this should work as the Wii software actually has to be running for the board to sync, you don't mention if the game is currently running when you have tried this so give it a go and see how you get on.
Hope this helps and thank you for using FixYa
Nintendo Wii Fit... | Answered on Jun 27, 2014
Have you synched it, i personally have never used the balance board, but there should be a sync button. At the bottom, push this while your wii or wii u is on.
Nintendo Wii Fit... | Answered on May 30, 2014
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Nintendo Wii Fit... | Answered on Feb 17, 2014
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Nintendo Wii Fit... | Answered on Feb 03, 2014
Nintendo Wii Fit for Wii Logo
412 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
weight
  • Video Game Consoles & Games
