20 Most Recent Canon EOS Digital Rebel XS / 1000D IS Digital Camera Questions & Answers
Hi.
Test using a different battery. When it does like that it is often the battery shorted inside. If the problem occurs using a known-good battery, then the contacts in the battery slots or the circuits behind the contacts have a short. When there is no battery the shorted wires or contacts are not "hot" and the short does not prevent the camera from starting.
If the problem is not the battery the camera must be disassembled. In that case disassembling will start from the screws on right hand side (watching from front), then screws in front, then left and back. Unless you have done similar repairs before it is advisable not attempting to disassemble the camera. The camera is very easy to damage. There are springs, wires and tricky parts near to shutter button on top, selector wheel and strap holder. If problem is camera and not the battery you can get a good quote on repair here:Repair.
Regards.
Ginko
Canon EOS... | Answered on Oct 10, 2019
Hi. Take a look at the below link, it may be your solution.
Canon Rebel xsi Err 05
Canon EOS... | Answered on Jul 08, 2019
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Canon EOS... | Answered on Dec 01, 2018
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
Thank you for your sunshine. This is not the kind of query with which Fixya can really assist you, I'm afraid - have you thought of consulting the many on-line forums which exist to offer advice on exposure and software. Good luck.
Bad Circuit board in the lens, Needs to be replace by a Repair Tech, tccamerarepair.com
Canon EOS... | Answered on Feb 01, 2018
Card was removed before the camera was completely shut down or whilst software was being updated. Camera is 'bricked' will need to be sent to canon service agents for repairs.
Canon EOS... | Answered on Sep 24, 2017
Use the menu to unprotect the image then you can delete. Also you can format the card but that will remove all the images on the card so make sure you've saved it elsewhere.
Canon EOS... | Answered on Sep 02, 2016
press menu 5th menu along select item 1 up from bottom (live view function setting), select enable then quit menu press set button to activate live view
You can't burn raw pictures. They are only data from a camera....not an actual picture. They must be processed in an editing program and then converted to another format such as jpeg or tiff.
Canon EOS... | Answered on Nov 04, 2015
You need to have your camera serviced.
Canon EOS... | Answered on Nov 02, 2015
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Canon EOS... | Answered on Oct 29, 2015
Switch on, Remove any lens you have on, Switch off,remove the battery and reinsert after 30 seconds switch on re-attach the lens.
Canon EOS... | Answered on Mar 02, 2015
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Hard to tell, but I'd give a slight advantage to the Canon 1000D over the Nikon D60 (closest competitor) for 2 main reasons. The Canon has liveview which the D60 lacks and the Canon is largely backwards compatible with older Canon and third party lenses - so you can get good quality older lenses which will work perfectly with the 1000D. With Nikon on the other hand you need to either buy lenses with internal autofocus motors or you'll be stuck with only manual focus.
Besides that there's not really much difference, since both cameras produce great images and are very similar in features handling and price etc. To sum it all up - I suggest you go with the Canon.
Hope that helps with your decision.
Canon EOS... | Answered on Feb 18, 2015
It may just be too dark for action photography. Try turning your ISO up to 1000+. Set your computer in Tv (Time Priority Mode). Use the top wheel to adjust the shutter time to something like 200 or greater. Keep an eye on the aperture value. If it starts flashing, you don't have enough light to support your settings.
Canon EOS... | Answered on Jan 23, 2015
Try a factory reset. I wouldn't try and remove the battery.
Canon EOS... | Answered on Dec 28, 2014
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Canon EOS... | Answered on Dec 27, 2014
Are you trying to create a folder in the camera or on a computer. If in the camera it should create a folder for the date you are shooting automatically. Rich
Puzzling??? but remove battery and turn off red eye reduction after reinstalling battery. Rich
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
504 questions posted
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
when try download images direct
  • Cameras
