20 Most Recent Sanyo Xacti VPC-T700 Digital Camera Questions & Answers
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sanyo Xacti... | Answered on Mar 26, 2016
contact SANYO we do not have any here
Sanyo Xacti... | Answered on Jun 02, 2015
It's no problem at all to get them back. Do not take any more pictures, and remove the card from the camera to lessen the chance of you overwriting some important pictures or videos. There are VERY many freeware software options available to help you recover your files. Please see this blog article that reviews several of the better freeware recovery programs that you can download. You may need to use a card reader with these programs though.
All the download links listed in the article are available through CNET. This was to primarily ensure through CNET's verification process that these would be malware free software, and to also give you a chance to read user reviews on the software before downloading.
Sanyo Xacti... | Answered on Jun 30, 2014
Hey,
yes, with a file recovery software for example
http://www.quetek.com/prod02.htm
Let me know if you need anything else.
Thanks,
Ekse
Sanyo Xacti... | Answered on Nov 15, 2013
Obtain or purchase Battery Checker. $10 or less. Then test the batteries. If charged, disregard red light and pull batteries from charger and disconnect charger.
Sanyo Xacti... | Answered on May 30, 2013
Try cutting a small thin card the same size as the top of your battery. Try a card no thicker than a playing card. Place it on top of you battery then close the battery door. This should give the battery a stronger contact, and it may work.
Sanyo Xacti... | Answered on Jan 11, 2013
The card has become corrupted. See the corrupted card procedures in this linked article.
Sanyo Xacti... | Answered on Oct 30, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sanyo Xacti... | Answered on Sep 10, 2011
Welcome to Fixya
I am sorry to inform you that the manufacturer (SANYO) only created drivers for the following platform: Windows XP, 2000, ME / Mac OS9.0 or above and not Windows Vista. Please click here.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sanyo Xacti... | Answered on Sep 08, 2011
Hello Karen,
Please look for lock in memory card as in the above image. If the white latch is in downside position then slide it in up position. Also check that you are inserting the memory card in right position in the camera.
Sanyo Xacti... | Answered on Jul 03, 2011
"my exacti wont turn on"
Hmmmm .... did you put good batteries in it? Digital cameras are kind of particular that way.
Sanyo Xacti... | Answered on Jun 29, 2011
You can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/product/Downloads/VPC-T700_OM_English-47543903.pdf
Sanyo Xacti... | Answered on Jun 01, 2011
hi Usually white screen problem is defective lcd unit. your local repair shop would charge $45 to 75 depend on what they want to charge. Thanks and best regard!
Sanyo Xacti... | Answered on May 24, 2011
If there is visible damage on the lens then there has likely been a physical blow to the lens that may have forced it back. These lenses are made with plastic gears for zoom and focus and they break easily. The first part of the power up cycle is to check the lens and if it gets no reaction then you won't be able to power on.
Unfortunately (or fortunately depending on your view) the camera prices are coming down so fast that most repairs aren't worth the investment as they start generally at $100 and go up from there. Since this is at least a four year old model the equivalent replacement is likely considerably cheaper and better than your current model.
Sanyo Xacti... | Answered on May 23, 2011
sure you can buy a replacement charger for Sanyo Xacti VPC-T700 Digital Camera.
visit amazon by fallowing the link i posted bellow.
it is $14.
http://www.amazon.com/dp/B003VV79FO/ref=asc_df_B003VV79FO1535478?smid=A2IJTG4QNZI7ZK&tag=dealtmp4665-20&linkCode=asn&creative=395105&creativeASIN=B003VV79FO
Hope this solution works.
Sanyo Xacti... | Answered on May 11, 2011
Sanyo Xacti VPC-T700 Digital Camera Logo
165 questions posted
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
recover deleted photos
  • Cameras
