20 Most Recent
Dual Electronics CECT P168 Cellular Phone Questions & Answers
Web browser does not support frames
i) usually browser in some mobiles donot support frames(web pages are usually build using frames), so instead of using ur inbuilt browser......try to use an external browser from internet
try download "opera mini 4.2" using the website "http://www.opera.com/"(if your phone supports java applications) and copy it to ur memory card(phone memory card)
ii) it will install on ur phone, you will get enriched experience of browsing, which would be similar to browing on ur computer..........
Thanking you
M. Sridhar
Why is my iPhone 5 so slow?
That app is likely only testing the network speed of your iPhone, and if you're using a cellular connection instead of WiFi, the results will depend heavily on which provider you're with and they're coverage in your area.If you're using the same WiFi on all your devices, the iPhone 5 should not be slower than other iPhones, there are multiple reasons as to why it is getting slower speeds however.If you're running the tests at the same time, they may interfere with each other so run them one after the other.If you're already doing that, your router may be prioritising the other devices over your iPhone 5, assuming other devices are using the internet at the same time.
When I try to use
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To
call the number from your speed dial list, click on the "Phone dial"
icon, and hold the number down. For example, is the number 2 is home,
hold 2 down until you see it dial and there you have it.
Hopes this helps
When I try to connect
i have the cect phone and i inserted my sims card and now its says closed but will not let me call or text anyone. anybody know how or wat the problem is please help! asap write me back helllp hellp
Thanks so much!
Charger Error Pop Ups
dear,
this issue directly related with the charging circuitry... the issue
can either be with the charger itself or majorly with the charging ic
i had faced this problem with the chinese mobile phone but this can be
either with the chinese model or can be with the other...so check the
both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
Wifi problem
all you need to to is to delete the old APN as access point name and then put in the new one so that you can access it directly on your mobile if you are using the sim mode.
INVALID IMEI NUMBER
type *#06# for checking the IMEI
hope it would help u
(plz rate me )
thank you.
How to unlock Huawei Phone G7010
Hi,if you want to unlock a Huawei G7010 Mobile Phone from network lock visit the site
SuperUnlockCodes.com here they are providing the unlock code at low cost with easy step by
step unlocking instructions.Using that you can unlock your phone
easily.This is the easy,safe,fast and permanent unlocking method.
