20 Most Recent
Sharp MX-2700N Color Copier Questions & Answers
Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
When scanning, received error message
If your network is set up to DHCP your leases may have expired and your server may have given new IP Addresses to the destinations you want to send to. Check in the settings of the MFP (copier) that the IP address matches what the IP Address (check at the computer as well) on the computer is. When all else fails (including reboot of all) reinstall the software.
How do I remove Error code L4-02
L4 errors relate to motors. L4-02 specifically means Paper feed motor locking trouble.
You will need to take it in for repairs.
I have a sharp 2700 copier with code H5-01
HI
H5-01 means you have had five consecutive jams, it would suggest there is either something blocking the paper path, or the paper is not being picked up at all.
Try resetting the machine by the following:
Program, *, clear, *
It will then ask for a simulation code, enter 14 and press print, are you sure?, press yes. Clear all, clear all, should reboot the machine and try again.
If it continues to jam, try a different cassette.
Cheers
Andy
Dual sided scanning - how?
From the scan section, chose your recipient(s) first.
Then go to Image Settings > Auto/Original >
Choose 2-sided booklet or tablet, choose portrait or landscape orientation. Then scan as usual.
I believe you can also make this a default under System
Settings > [Admin Login] > Image Send Settings
