20 Most Recent Belkin N Wireless Modem-Router F5D8633au4A Questions & Answers
2answers
Setup with roadrunner
Connect Router - Desktop
Open RSP By typing 192.168.2.1
On the Left side under Internet WAN Click Connection
Type
Leave the password blank and click Submit
The Connection Type Should Be Dynamic
Click Next
There should not be any Host name & Click apply
On the left Side Click MAC Address Under Internet WAN
Click Clone And Click Apply Changes
It Should Work
5/12/2020 9:59:22 AM • Belkin N... • Answered on May 12, 2020
Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help...
Any printer can essentially be made into a "Networked" printer that function is all a function of software. You can usually, use any WiFi printer, as long as you know it's address, and can connect to it. Install the drivers and connect to the, WiFi, Networked Printer. A WiFi networked printer, is essentially seen as a "PC". It simply has an Address, and you just "Connect to" that address...
11/13/2019 5:57:12 PM • Belkin N... • Answered on Nov 13, 2019
Belkin n wirelss router setup
To setup the router you will need to log in to your router's control panel. This certainly won't be as simple as on the installer disc, yet it is still do-able. You might also want to contact Belkin's free technical support hot line. They can help you set it up with the method I described above.
8/25/2018 9:13:31 AM • Belkin N... • Answered on Aug 25, 2018
2answers
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
8/16/2018 7:05:10 PM • Belkin N... • Answered on Aug 16, 2018
Hi my Belkin N300 wireless moden router works for
If the green light is one of the port lights, then your network is switching into 10mbs (Orange = 10mbs, Green = 100mbs) - it may be a dodgy cable but more likely a faulty network card in your PC.
5/19/2018 1:40:04 PM • Belkin N... • Answered on May 19, 2018
I want to download setup cd belkin wirless router
Hi i got your issue ......
PLease go to this link and check www.belkin.com/support and you can download....
If you still have any queries contact 24/7 belkin technical support 1800-2235546
Thanks.....
With regards ......
Priya ,,,,,
4/23/2018 8:04:18 AM • Belkin N... • Answered on Apr 23, 2018
My belkin N router always
Disconnections are generally relative to the Internet Provider and Speed. If the speed drops, the router can disconnect and reboots. Just make certain you always update all drivers and especially if you are in Windows, keep up with current updates. Check your device drivers and do update from there also.
2/7/2018 10:34:40 PM • Belkin N... • Answered on Feb 07, 2018
5answers
No internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
12/4/2017 10:19:27 AM • Belkin N... • Answered on Dec 04, 2017
Cant install it the usb to windows 7
You can download the drivers form the website,
1.Download the driver and save in your computer
2.right click the driver and click on properties
3.you will have compactability,click on it
4.In the run this program,"select it as Windows Vista SP2" and then click on OK
5.Now you try to install the drivers it will install and then check for your wireless connectivity in your laptop
Regards,
Ayyasam
4/19/2016 8:45:21 AM • Belkin N... • Answered on Apr 19, 2016
I can access WIFI everywhere but home.
you may have to give access permissions to the Belkin router in the wireless setup.
2. By MAC address from the Ipod touch.
3. here is the Belkin site to assist you in setting up your wireless device.
http://en-us-support.belkin.com/app/answers/detail/a_id/22/kw/F5D8633/p/312%2C316/page/2/r_id/166
7/21/2015 9:41:08 AM • Belkin N... • Answered on Jul 21, 2015
My laptop wont log on to belkin
Sir, Check your IP Address, Maybe its conflict with other device. My advice to turn it automatically. Or Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router. Perform the steps below to set up your Belkin router through the web-based setup page. NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router Step 1: Unplug the modem and router from the power source. Step 2: Connect the modem to the WAN or Internet port of the router.
7a2d9691-2d05-4a84-8c84-2dbd7c1da14f.png Step 3: Power ON your modem first, then your router by plugging them back to the power source. Manually setting up your router Step 1: Connect the computer to one (1) of the Ethernet ports of the router. 53d87d4f-f0e2-4bc0-a2ee-20571d20d693.png Step 2: Launch a web browser and enter "192.168.2.1" in the address bar. caaa1424-71a1-4705-a257-5c83bb988d1a.png Step 3: Click Login. f43cf160-b3ef-4848-ae4a-ae3797a563b4.png Step 4: Leave the Password field blank and click Submit. 40e8d69f-22a6-4f6b-8eaa-2446bf156833.png Step 5: Under Internet WAN, click Connection Type. 7e28a43e-cefa-485a-923d-5d6ae2c6fce0.png Step 6: Select your Connection Type, then click Next. d93ad37d-1fb2-41b6-b1ca-8a5e9a5d8c4b.png NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below: Cable Internet Service PPPoE / DSL Static IP Account Step 7: Enter the details provided by your ISP and click Image. You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected. 116f45be-cc94-4208-82b8-1afa55cb7ea5.png You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices. as mention On official Belkin website vedio for Belking Online Support: Setting up the Belkin router using an iOS device Video Belkin Or In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
3/28/2014 4:43:00 PM • Belkin N... • Answered on Mar 28, 2014
0answers
2answers
No internet when connected to router
  • Reinstall product as per user manual exactly & connect router directly to the MODEM.
  • Try connecting with a wire [ethernet] cable at first to set up PSK (personal shared key).
  • Ensure PSK is correct at log on to network on wireless device.
1/15/2014 1:38:28 AM • Belkin N... • Answered on Jan 15, 2014
How do i find my wpa2 key for my belkin router, i
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
12/13/2013 2:38:26 AM • Belkin N... • Answered on Dec 13, 2013
Is it possible to reset the lexmark cartdrige 29 ?
1st this question probably doesn't belong in Wireless router problems. 2nd. You can refill some cartridges, but newer version are "date stamped" so even if you refill it, it won't work past the date stamp. Always check when you buy and get the newest boxes, Clearance ones are usually on clearance because of the expiration date.
11/20/2013 2:12:24 AM • Belkin N... • Answered on Nov 20, 2013
Do i need a modem? if so which are compatible?
When you speak to Comcast you should see if they are providing you with a wireless modem/router that will be everything you need.If so, you will not need the Belkin router as Comcast will supply you with the hardware you need. If they only give you a modem, your Belken wireless router should work fine with the Comcast modem.Hope that helps!
7/25/2013 10:49:33 PM • Belkin N... • Answered on Jul 25, 2013
Lost my setup disk for my Belkin wireless router
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
7/3/2013 2:01:14 AM • Belkin N... • Answered on Jul 03, 2013
How do i
If you want to reset the settings of your router, you have to press and hold the reset key for more than 30 secs. After that power off and then restart your router.** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
5/1/2013 6:02:54 AM • Belkin N... • Answered on May 01, 2013
Belkin N Wireless Modem-Router F5D8633au4A Logo
307 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
conect wireless router regular modem
  • Computers & Internet
