20 Most Recent
Royal Satellite 40 Typewriter Questions & Answers
INSERT CORRECTION TAPE
Go to nadist.com you will find aaa Nakajima that is the same you can down load a manual.DickyO
Typewriter beeps and does not move
It sounds like you have to reset your margins,the beep is telling you that it is at the end of the line.To check this press enter(next line) and see if the typewriter goes to the next line if it does that is your problem
I can't get the paper
There is probably a label or other debris on the paper tray. Open the cover, on the L. end of the platen you will find a latch, press it down, lift the platen up and slide it to the left, now you will be able to remove debris.
DickyO
It has been a couple years that the typewriter has
If there is no noise, movement or lights the power supply is most likely bad. If you pack it well and ship it to us we will give you a free estimate. It won't cost anything unless you choose to repair it.
DickyO
Cleveland Business Machines
2327 St. Clair Ave. NE
Cleveland, Ohio
216-241-0027
