20 Most Recent
Gold Medal 2086 Popcorn Maker Questions & Answers
Popcorn
popcorn joe,
yes,thats the best way to add flavor to ur popcorn..
u can taste the flavor better and enjoi it better..
hop i did help..
Kettle motor wont come on and light wont come on
Check that the wall outlet is good by plugging something else into it. Plug the pop corn device into the outlet. Bend the power cord at both ends to see if the unit lights up. If not, you may have a bad connection inside or a bad switch. There also may be a blown fuse inside you could replace.
Gold Medal 2086 popper electrical
I'm not sure if this will be helpful or not...
The 2086 in the picture looks like the Ultra P-60 with the copper finish (Part #1866 at http://www.gmpopcorn.com)
You can get some manuals & schematics at the Jarco website:
http://www.concessionstands.com/s.nl/it.A/id.307/.f (The machine is listed there under part #2086, by the way; is this where it came from?)
Anyway, hope this info is of some use.
B. Bryan
Buda, Tx
I have a Gold Medal Popcorn Machine 2086. The
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
I have a gm 2086
That depends on which part you are cleaning. If you are trying to clean the heating element of the machine, do not attempt to use excessive force to remove the grim. It is normal to have a little brown coating on the heating element in popcorn machines.
However if you really desire, you should look for a stove or grill cleaner. They are usually a white fluid that you leave on, then scrub and remove. After that wash it with soap and water to remove the cleaner itself before using.
Thermostat hook up
I actually just had a pleasant experience contacting Hellman Group, (The manufacturer of Nostalgia Electric popcorn machines). I called the main number, pressed 1 for customer support, and after 3 tries (got an answering machine the first couple of times), I got someone in customer service who was able to help me get the part I wanted. Not sure if they can give you a wiring diagram.
The Helman Group, Ltd.
1621 Beacon Place
Oxnard, CA 93033
Electric heat thermostat wire melted
The cause is a loose wire nut which creates arcing. This is a very common problem and the cause of many fires -- it's a result of low quality work.
Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
What was the use date on the Gold Medal flour?
You are probably concerned about the recent Salmonella issue?
The product is the UNBLEACHED all purpose flour:
Gold Medal Unbleached All Purpose 5LB Flour Package UPC: 000-16000-19610-0 Recalled Better if Used by Date: 20APR2020KC
The "use by date" is ink dot printed on each package, usually toward the bottom of the package somewhere.
