20 Most Recent
Nakajima AE-740 Typewriter Questions & Answers
How to reset margins on kx-r340 typewriter
Hi;
To set or change the left margin space forward and press the left margin key. If you want to go in the other direction the press the margin release key once(do not hold it down) the use the backspace key to get to the point where you want to set the margin and press the left margin key.
The setting of the right margin works the same way.
Andrew
I need to clear tabs
tab to the set tab, push the tab clear button.
But if you are talking margins, you can only move them. Not clear them.
Tab and return
reset the left margin at 69, or return and then press tab to start a new line
Return to tab
Don't confuse tabs and margins, after a return it always goes to left margin. Use the tab key to go from the left to the next place where you set a tab
Can you change the font on the AE 740
yes, but you have to change the typewheel
if you don't have the user manual, can get it from here
http://www.manualslib.com/manual/455216/Nakajima-Ae-740.html#manual
How do you remove the tab set
You probably have the L. margin set there. Return to that point, press but don't hold the MAR REL key, backspace to desired location, press L. MAR key.
DickyO
