20 Most Recent Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W Questions & Answers
3answers
Looking for engine for a generator I bought on
Would need make and model......check Harbor Freight......Northern Hydraulics......
12/28/2018 3:49:46 AM • Porter Cable... • Answered on Dec 28, 2018
I have a PC 6500
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
11/12/2017 12:45:46 PM • Porter Cable... • Answered on Nov 12, 2017
What oil to use in Honda GX390
10w30 HD
6/21/2016 2:52:51 AM • Porter Cable... • Answered on Jun 21, 2016
0answers
0answers
0answers
This is for the Porter Cable H650IS-W-1 Contractor
I do not think that your generator has a voltage regulator. The solenoid is for idle only when there is no demand (power being used). You can verify this by examing the governor spring /tension adjuster on the engine. Idle control switch on panel and the assembly board control the solenoid. When the assembly board fails generally the generator will function the same however there will be no idle. I have checked with Dewalt and parts are available however expensive. If idle is the only problem you may consider ignoring issue. If there is another problem with gen. please email.
11/27/2010 4:01:57 PM • Porter Cable... • Answered on Nov 27, 2010
Does anyone know how to remove the rotor assembly
I am assuming that you have removed the end bell with field winding and the only obstacle is the rotor on the crank of the engine. I am also assuming that you were able to remove the long bolt thru rotor into crank. Now you will need to apply penetrating oil to the shaft of the engine to loosen the rust on the taper (tapered shaft fits very tightly into core of rotor). It may take several applications. Place a piece of hardwood against metal to protect the rotor and firmly rap with hammer on both sides. You may need to use pry bar against engine and rotor as you hammer hardwood. Repeat as necessary, some rotors will be very stuck due to rust. Good luck.
10/3/2010 10:38:51 PM • Porter Cable... • Answered on Oct 03, 2010
My generator runs but doesnt put out to the
You may have to check the wiring, With the engine off check the following: they may be a loose wire, the brushes on the generator may be too worn. Check for continuity from the outlet all the way to the generator.
6/6/2010 8:50:14 PM • Porter Cable... • Answered on Jun 06, 2010
Not generating power
check
avr / brushes if it has them
if not capacitor and diodes on the end of the armature
4/4/2010 5:44:29 PM • Porter Cable... • Answered on Apr 04, 2010
Porter Cable T5500 generator - engine racing - no
Have you checked to see if the breakers have tripped?
1/30/2010 3:26:01 PM • Porter Cable... • Answered on Jan 30, 2010
No start
The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clen the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
9/19/2008 8:18:29 AM • Porter Cable... • Answered on Sep 19, 2008
Porter cable CTE 300 OIL TYPE
The Porter-Cable CTE 3000 generator uses SAE 10W-30 motor oil.
3/19/2023 3:12:55 PM • Porter Cable... • Answered on Mar 19, 2023
My porter cable 7500 watt generator does not consistently produce 220 volts it fluctuates below 220 why is that
Usually dependant upon load and RPM of engine.
9/24/2021 6:33:38 AM • Porter Cable... • Answered on Sep 24, 2021
I have a porter cable generator CTE3000, need to know the type of oil to get thanks
You can contact your supplier who supply the generator to you. They know details about their product.
12/31/2019 8:50:10 AM • Porter Cable... • Answered on Dec 31, 2019
Where is the oil drain plug on a Porter Cable BSV550-W located?
What is a BSV550-W
6/11/2019 6:18:41 PM • Porter Cable... • Answered on Jun 11, 2019
Porter Cable 6,500 Watt Contractor Portable Generator #H650IS W Logo
17 questions posted
Top Porter Cable Electrical Supplies Experts
Jay Finke
Jay Finke
CJ Rock
CJ Rock
ADMIN Andrew
ADMIN Andrew
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Porter Cable Electrical Supplies
Most Popular Question
anyone know remove rotor assembly
  • Electrical Supplies
