20 Most Recent
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter Questions & Answers
Constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.regards
Why Constant beep
See previous answer, take it apart and rebuild it again might be best
Why constant beep?
It seems that something isnt properly seated. Dismantle it and put it together (mantle it?!) very positively this time, make sure the freewheel latch is fully home.
5 beeps intermittent
Hi 5 bleeps is a brake issue , it's either the micro-switch or the connection to the brake from the connectors that are located from the frame to the rear sub frame.. I can get these parts for you cheap..
Regards
Rob
www.gewizrepairs.co.uk
Why won't my mobility scooter go?
Three things you might try:
1. Make sure the charging cable is not plugged into the battery pack.
2. Make sure the transaxle is engaged. Try changing the position of the manual freewheel lever.
3. The "horn" also gives diagnostic codes. See if there is a repeating pattern to the beeps and compare them to the code chart.
My scooter is making loud clicking sounds as
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
