20 Most Recent
Tanita 1479V - Digital Pocket Scale / Jewelry Scales Questions & Answers
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00This is more the scale costs.Moral of the story. Don't buy Tanita.
What does Errh mean?
Display - (ErrH) Errors - The value counted at zero point is too small.Items to be checked - Distortion of the load cell assembly.Repair & replacement methods - Replace mechanical assembly.BASICALLY - The error mention relates to a distorted/damaged loadcell. It will be uneconomical to repair this unit.
My ProScale XX 250 shows out2
I had this problem with my Silvercrest kitchen scales model z30170. Being wall mounted the weighing platform was on a fold-down flap . It turned out to be a broken wire in the hinge joint.
Wont turn on tried new batteries
I have repaired 1479 model with same problem.
check the battery contacts especially the + side i found that it retracted 1-2 mm back thus not making contact
jb
Why dose my proscale orion 150 pocket scale say out2
It's possible that the tray is pushed into max position.
Incurred due to an overload on the tray for a long time or a unprotected transport probably ...
Try turning it on, while holding the tray pulled up (eg scissors sliding under the tray to keep it elevated) and if the scale will show you "0.00", the tray is pressed...
Can i pay my ebay fees over the phone
no you can't, you can only do the following;
automatic payment
one time payment = either credit card, paypal, or you can send check using the coupon in the site map page.
here's how:
1. go to www.ebay.com and sign in to your account
2, then click site map located on the upper right hand corner of the page
3. scroll at the bottom and click make a one time payment
and you will see your options.
hope this helps. see ya round!
My Tanita KD-300 is showing err6 - what should does it mean?
It seems that the error code "Err6" on a Tanita KD-300 scale indicates that there is a problem with the measurement sensors or the internal circuitry of the scale. This could occur due to a number of reasons, such as a buildup of dirt or moisture on the sensor, a loose connection, or an issue with the battery or power supply.
One potential solution is to try cleaning the sensor and making sure it is properly connected. If the issue persists, you may need to contact customer support or consider having the scale repaired.
It is worth noting that the Tanita KD-300 model is an older model, and some of the solutions mentioned in the search results may not be applicable to your specific issue. It is recommended to consult the user manual or contact customer support for more information on troubleshooting the issue.
