20 Most Recent
Reebok Fit Watch 10M Strapless Heart Rate Monitor Questions & Answers
I had a battery shop replace the battery and have
This is what worked for me.Press & Hold MODE till it FLASHES (Seconds will flash first), thenPress ST/STP and it will jump to MINUTES, thenPress the LAP/RESET till desired Minutes. Once you do, Press ST/STP and it will jump to HOURS, then Press the LAP/RESET till desired HOUR (if you go past 12 it will then show p.m. and vice versa for a.m). Once the Hour is chosen, Press MODE. DONE!
Reebok heart rate monitor won't work after new battery.
I contacted SportBeat Inc. with the same problems you reported. I sent back the old watch with a $20 check to have them replace the "module". (This is what they told me over the phone to do.) They sent back a brand new watch in less than a week, and returned my check! (Maybe I was still under warranty?) Anyway, their phone number and address are on the back of the manual. They were very responsive to phone calls and emails. Good luck!
Sport Beat Inc.
45 Jefryn Blvd.
Deer Park, NY 11729
1-888-760-3059
The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Setting time
To get the manual from the Reebok site, you need to know the model number (not 10M). The Reebok site says you can look on your user manual for this ?!?. If I had my user manual, why would I be online looking to download a user manual?
Anyway, there is another response below that answered my question.....
You have to hold down the mode button until the time starts flashing, hit the mode button again to get hours. Adjust with the stop/start button.
Hope that helps...
Setting the time
It took us 2 days, but my husband and I finally figured this out.
Press and HOLD the Mode button until the time display starts to flash. Press the mode button again until the hours are flashing.
Use the Stop/Start and Reset buttons to move the time up or down.
Press the mode button again until everything stops flashing.
