20 Most Recent Casio Privia Keyboard Case Questions & Answers
Try this driver.
https://code.google.com/p/casiousbmididriver/
Casio Privia... | Answered on Oct 26, 2015
Hi, This is very likely to be a dirty key contact.
If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact.
All the best, Chris the Fader.
Casio Privia... | Answered on Sep 21, 2014
You may be running out of internal memory. Try deleting, songs & SMF etc that you may have recorded to INF AFTER moving them to an SD CARD first.
IDES4 can also be used to move user tones etc and do a factory init.
Casio Privia... | Answered on Aug 12, 2014
If that is one of the ones with a plastic "hinge/spring", breakage is usually fatal... keep cord and plug for junk box.
Casio Privia... | Answered on Sep 11, 2013
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Casio Privia... | Answered on Jul 14, 2012
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Casio Privia... | Answered on Jun 04, 2011
I suspect that a NOTE or other selection button is "stuck", if not physically, then electrically.
the startup of most of these devices scans the keyboard and control panel to insure all user inputs from them are at rest. When it sees one stuck, then sometimes the system hangs.
Casio Privia... | Answered on Mar 08, 2011
Page E11 of your manual.
If you don't have the manual, download it here for the PX300:
http://www.manualnguide.com/download/manual-guide/casio-privia-px-300-digital-piano-users-manual.html
Note... other models will be similar in method for the metronome.
Casio Privia... | Answered on Feb 08, 2011
Key contacts have got contamination. They are typically conductive rubber that press rubbber pills against circuit board traces. You can clean them with 99% isoprphyl alcohol and Q tips, but it is a lot of work disassembling and great care has to be used. There are two per key which allows measurement of velocity by the delay between the two contacts.
Casio Privia... | Answered on Feb 05, 2011
First verify that the pedal you are trying to use is the correct sense, either normally open as most or normally closed like Roland types. Jacks if physically broken can be replaced. Unit has to be opened and correct jack replaced or in some cases the jack has just broken loose from the solder on the board.
Casio Privia... | Answered on Dec 28, 2010
Casio Privia Keyboard Case Logo
45 questions posted
Top Casio Music Experts
Michial Gueffroy
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
one black key not make sound
  • Music
