20 Most Recent
Bosch Electric Table Saws Questions & Answers
Motor brushes spark like crazy!
If you already replaced the brushes you could have a couple problems, the least is the armature commutator needs cleaned and the more expensive is that it needs replaced. This is a problem unless you want to tackle taking the motor partially apart. Let me know what route you want to take either a repair center or looking at the commutator.
My table saw will not
Is there anything blocking the blade from rotating it sounds like it is jammed or locked.
My Bosch 4000 blade will not go down any farther
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
What's the smart way to remove the motor for
i wouldn,t remove unless you think needs new bearings or cannot get to the brushes, turn upside down if has base cover remove and blow out best you can be sure no water in air line.
Bosch TS2000 and the blade won't move to lower or
problem was solved by our handy man he replaced a washer and used candle wax to lubricate the part and it seems to have done the trick. I am still however looking for a manual for the Bosch TS2000 table saw as my husband has miss placed it. I guess I would address the Bosch company for that.
Thank you
Linda
Blade won't go up and down
Make sure the lockring on the adjustment handle is pulled out. If so, than you've got to clean the adjuster rod and lubricate it.
Installed new brushes but does not come on is
no. do you have a volt ohms meter to check continuity, if so unplug tool and start with the cord to the brush holders, if you get nothing backtrack to the switch. Let me know what the brand and model number is and I will try and help firther. Why did you replace the brushes? were they burnt or the spring collapsed? If so the commutator might need cleaned, but that comes later Let me know
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Bosch 1587vs blade won't tighten when installing
It sounds like you are having difficulty tightening the blade on your Bosch 1587vs jigsaw. To resolve this issue, first unplug the tool and lift up on the knob and loosen the spindle lock. Then insert the blade and push up slightly while doing so and twist to align the blade with the roller. Make sure to turn past resistance until it clicks. If the issue persists, you may need to replace the "clic" assembly, part #2-602-025-901.
1/4/2023 1:09:33 PM •
Bosch Saws
Answered
on Jan 04, 2023
Lower blade guard alternatives?
It sounds like you've called all 3rd party locations. Please call Bosch directly and request the part. And if they don't have it in the U.S. then you can request the phone number for their international locations. The U.S. phone number is 1-800-944-2904. Otherwise, I would search on ebay and alibaba to find the part that you've mentioned.
Thank you.
12/27/2022 1:22:53 AM •
Bosch Saws
Answered
on Dec 27, 2022
