20 Most Recent Makita HR2010 13/16 Rotary Hammer, SDS, variable speed, case Questions & Answers
0answers
Sds drill max
Be the first to answer 1/16/2014 11:20:01 AM • Makita HR2010... • Posted on Jan 16, 2014Be the first to answer
So does the hr200 work
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
12/23/2010 4:46:20 PM • Makita HR2010... • Answered on Dec 23, 2010
I have two Makita chargers and three batteries of various ages. battery chargers no longer charge the batteries.
Do you leave them plugged into the mains all the time? Voltage spike possibly. They can be repaired, but you need the model number in the search query. https://www.google.com/search?q=Makita+charger+repair ..
7/22/2023 12:37:37 AM • Makita Drills • Answered on Jul 22, 2023
2answers
My Makita impact driver led light stays on soon as the battery is clicked in. Any idea whats wrong and how I can fix it?
the light is normally activates by the trigger, so either the switch has gone faulty or the wires running to bulb are contacting. press the helpful button and check link below Makita BTD142 Trigger Switch Replacement
3/7/2023 1:12:49 AM • Makita Drills • Answered on Mar 07, 2023
Makita charger DC18RC i need electrical scheme or D14 diode value .
The Makita DC18RC charger is equipped with a diode labeled D14 that helps regulate the voltage. It is a 1N4007 diode, which is a 1-Amp, 1000-Volt diode. You can find the electrical schematic for the DC18RC charger online with a quick search.
2/16/2023 9:43:01 AM • Makita Drills • Answered on Feb 16, 2023
Electric Makita HP2051 chuck won't close
I don't really know how a chuck works. I use them often on a drill press, cordless drills, etc. My grandfather always said to "check the simple things first." Could something have gotten in the way like saw dust, dirt.....? ? I might suggest trying using compressed air and blow it out? You can buy a can of compressed air at office depot.
8/25/2022 4:27:11 PM • Makita Drills • Answered on Aug 25, 2022
Trouble shooting a makita dc18rc charger dose not turn on
There are no serviceable parts in this charger, it is a replacement item
6/14/2022 4:33:24 PM • Makita Drills • Answered on Jun 14, 2022
Gearbo assembly makita bhp452
You can try the website makitauk.com select parts then choose your tool. Unfortunately it does not break the gearbox down to any detail as it can only be obtained as a complete unit.
6/3/2022 5:18:10 PM • Makita Drills • Answered on Jun 03, 2022
I have an old Makita drill I would like to run with a new Lipo battery?
Lithium Polimer batteries are 3.7volts per cell. They need specialist charging and protection. Maybe not the best choice ...
4/15/2022 7:44:34 AM • Makita Drills • Answered on Apr 15, 2022
2answers
I have a brand new makita hammer drill and the chuck is not stuck. It opens and closes freely but the bit still wont come out? Any ideas what may be going on?
Hi. Just to clarify, it is a rotary hammer drill, not an impact drill? In most cases those machines put out 3 joules of energy on the back of the drill bit. If it was a cheap bit, the hammer action "mushrooms" the end of the bit making it difficult to remove. You could try to force it out using a bench vise, but you could damage the chuck.
7/24/2021 7:27:56 PM • Makita Drills • Answered on Jul 24, 2021
How do i convert a makita charger model DC18RC at
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.And the DC18RC battery charger has two volt 110 Volt and 240 Volt. The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.It can charge a Makita BL1830 Battery in approx 22 minutes.But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.The reason is as below:1. This will void product warranty ! If you follow this mod, you do it on your own risk ! 2. There are several comments that describedsame model # but with different design and components. Please beware that this mod might not work on your chargeror worst, will damage it. Only perform this mod if you know your way around with electronics !
6/12/2021 10:13:07 PM • Makita Drills • Answered on Jun 12, 2021
Hi I am having trouble with my DMR108 Makita radio. I keep getting this code appear and powerfail. I do not have a power cord with it or battery charger. I have replaced AA batteries but still can’t get it to find radio stations. It was my partners but he recently passed away. I don’t want to get rid of it if I can somehow fix it please.
I think this radio uses two different sets of batteries. There is the smaller batteries that store preset radio stations and a larger battery pack to power the actual radio. If your partner had other Makita cordless tools some of those batteries will fit and there will be a charger for them. I've put a link to a website for a users manual. (try looking at page 3. The larger battery will be a black block which is the same type used for the cordless tools. The squarer battery pack style should slide upwards towards the handle and the rounder shape battery packs should just pull out. Talk to a good builder or a Trade tool supplier and they may be able to help or order you the power cables you need. If not contact Makita directly and they will be able to help you. https://www.manualslib.com/manual/1339075/Makita-Xrm04.html?page=3#manual
10/25/2020 9:08:12 AM • Makita Drills • Answered on Oct 25, 2020
2answers
I have a makita hr4011c rotary hammer drill, was working perfect then stopped, plugged into transformer but green light has come on on the drill but no action from the drill,
Did you check to see if the motor is even being energized.? If not check the switch. If yes, then check motor brushes.
7/13/2020 11:57:48 AM • Makita Drills • Answered on Jul 13, 2020
Makita HR2010 13/16 Rotary Hammer, SDS, variable speed, case Logo
2 questions posted
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
View Most Popular
Makita Drills
  • Makita Drills
Most Popular Question
hr200 work
  • Drills
