20 Most Recent Bosch Die Grinder 1215 Questions & Answers
manual
Replacing carbon brushes
The housing cover is removed by removing the one Torx (t-20 or t-25 ) screw from the end of the housing where the power cord goes inside.  Once this screw is removed the brushes can be quickly replaced.  Go to this page for an exploded diagram.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/bosch/1215.034
The screw you want to remove the housing is listed as part 130 in the diagram.  Then the brush (part 801) can be unplugged an removed from brush holder (part 116) by gently pulling back the brush spring (part 126). Then the spring must be held back to install the new brush. Then plug it in, and replace the other brush, test the unit before replacing the housing cover.  The blue sparks generated by running the unit are normal and will decrease as the new brushes are worn to the shape of the armature.  Good Luck!
1/5/2009 8:51:32 AM • Bosch Die... • Answered on Jan 05, 2009
0answers
Replaced brgs. still gets hot
Your are over loading the grinder. Did you apply lubrication to the bearings?
8/6/2009 2:49:57 PM • Bosch Grinders • Answered on Aug 06, 2009
3answers
Price for used Grizzly G1550 metal lathe
depends on condition and what comes with it. generally starts at $500 in good shape and up to 850 if excellent with many extras (chucks, rests, knurling attach, faceplates, etc) Also, check for accuracy...
2/4/2023 8:24:56 AM • Grinders • Answered on Feb 04, 2023
May I eliminate a Circuit Breaker or protector from a Skill Mini Grinder 9310
Yes all the tool places say discontinued. Yes, bypass it, but make sure you don't overwork the grinder. https://www.google.com/search?q=2610904741 ..
10/26/2021 11:13:01 PM • Grinders • Answered on Oct 26, 2021
My Makita DGA505 Angle Grinder with a BL Motor starts then quits. This is the second time it has happened.
Out of warranty ... time for a replacement machine.I would choose a different make. Assuming the batery is not the fault.
9/17/2021 12:07:38 PM • Grinders • Answered on Sep 17, 2021
Makita 18 volt angle grinder. Why does red light turn on and off with fully charged batteries?
DIRTY CONTACTS POSSIBLY
3/28/2021 11:43:14 AM • Grinders • Answered on Mar 28, 2021
2answers
How do I match a (start) capacitor for modern day replacement?
Size for size and component value identical on replacement. Fit the correct part.
1/14/2021 4:37:06 PM • Grinders • Answered on Jan 14, 2021
How do I get a manual for 55-3584-2 bench grinder
Considering how potentially dangerous grinding machines and wheels are and how much safety legislation exists about their maintenance, adjustment and use, a great deal of printed matter exists about these things and the wide range and selection of wheel material. You should have no bother finding useful information, fortunately bench grinders are extremely similar to each other... https://images.homedepot-static.com/catalog/pdfimages/b6/b64b39fb-6d42-4fec-a274-76bbd950e6d8.pdf
10/22/2020 10:27:47 PM • Grinders • Answered on Oct 22, 2020
Un plugged the wires from the switch and do not
Mmmm... that's a little more complicated. If you have a continuity / resistance meter, we can noodle it out, though. First, are the two white wires the ONLY wires coming from the motor? I suspect they are - that's not in conformance with any accepted color code, but it'll work. For the rest of this, I'll assume that the two white wires are the only ones from the motor. You'll need to meter the switch itself, with no wires connected to it. In the OFF position, you shouldn't find continuity between any of the four switch contacts. In the ON position, you should find continuity between two pairs of contacts. The black wire from the power cord should go to ONE of the two switch contacts in a pair that have continuity with the switch turned ON. One (either) of the white wires from the motor should go to the other switch contact IN THAT PAIR. That leaves you with one more pair that has continuity with the switch turned ON. The white wire from the power cord goes to one of those, and the second white wire from the motor goes to the other one. When you have it all wired up, plug it in & turn it on. If it's not right, it should immediately pop your circuit breaker. If it IS right, it should run fine. If it pops your circuit breaker, open it back up and swap one wire from the power cord and one wire from the motor.
10/6/2019 9:00:35 PM • Grinders • Answered on Oct 06, 2019
2answers
What does wrap 1, turn mean
One turn.
3/5/2019 10:10:25 PM • Grinders • Answered on Mar 05, 2019
2answers
I need an on/switch for
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
7/11/2018 7:56:15 PM • Grinders • Answered on Jul 11, 2018
2answers
NEED ON/OFF SWITCH FOR BUFFALO BENCH GRINDER
You can get a replacement toggle switch at any hardware store look in the electrical department.
7/11/2018 4:26:24 PM • Grinders • Answered on Jul 11, 2018
2answers
Given a bench grinder which did not work. How to test/fix?
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
6/13/2018 7:39:35 AM • Grinders • Answered on Jun 13, 2018
I need a Manual for Napa 1/4 die grinder
Jet 577102 is a bench grinder with 1HP motor. It has got guards on the grinding wheel. Dust vents and guard makes the grinder makes it an efficient grinder. 115 Volt is needed to run this high performance grinder.
6/9/2018 7:42:54 AM • Grinders • Answered on Jun 09, 2018
2answers
I OWN A OLDER SEARS GRINDER. I JUST QUIT ON ME . THE WHEELS TURN FREELY SO I BELIEVE IT IS JUST A RELAY. THE NUMBER ON THE RELAY IS ( 4CR-20-728 ). DO YOU KNOW WHERE I CAN BUY ONE.
Sometimes it could be like this contact by the centrifugal interrupter or the powerswitch or startcapacitor (only if its buzzing) an other kind of relay switch it should be simple to measure it .but to adjust it for time release can be ??. 1200px-centrifugaalschakelaar.svg-pwfz1boku4nuke3zn5s33jhx-4-0.png
3/12/2018 7:48:14 AM • Grinders • Answered on Mar 12, 2018
Need to convert from 220v to 110v. Where can I get a wiring diagram for an unidentified bench grinder?
To convert it its possible more expensive then buy an other grinder but there is some trick to connect in serial on the powercord a light bulb on a special choosen ability differs on the RPM or use a variable power resistor also in serial connection between on one of the 2 wires on the powercord.
2/28/2018 9:29:43 AM • Grinders • Answered on Feb 28, 2018
Bosch Die Grinder 1215 Logo
1 questions posted
Top Bosch Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Bosch Grinder Expert? Answer questions, earn points and help others
View Most Popular
Bosch Grinders
  • Bosch Grinders
Most Popular Question
replacing carbon brushes
  • Grinders
