20 Most Recent Poulan PP4218AV 18" Chain Saw Questions & Answers
3answers
Won't start. on/off switch stuck, choke won't engage.
Mine did the same thing. Take off the cylinder cover as described above. Take off the screw holding the on/off switch. <br /> Bend the bottom of the silver metal shutoff band down where it rides against the back of the switch. Bend until switch turns on and off smoothly.<!-- from fixya rte -->
6/18/2016 5:36:56 PM • Poulan PP4218AV... • Answered on Jun 18, 2016
What is vapor locking?what causes it?
I don't think your problem is vapor lock. Your machine is just starving for fuel. Your problem can be solved by removing and cleaning your carburetor, changing the gaskets, changing filter , and checking for bad fuel lines. Your problem is very common. GOOD LUCK FRIEND.
9/19/2014 5:18:47 PM • Poulan PP4218AV... • Answered on Sep 19, 2014
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
9/16/2014 4:20:11 PM • Poulan PP4218AV... • Answered on Sep 16, 2014
How to get your tigger from sticking on my poulan predator chaINSAW
Trun over saw look at BAC handle small screw should b there
6/3/2014 11:59:40 PM • Poulan PP4218AV... • Answered on Jun 03, 2014
0answers
2answers
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
8/9/2012 9:14:45 PM • Poulan PP4218AV... • Answered on Aug 09, 2012
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
7/16/2012 10:27:53 PM • Poulan PP4218AV... • Answered on Jul 16, 2012
0answers
I borrow a poulan wood
did you fill it up with the ratio of 25-1 of fuel and oil?
if not then the carb will be block and will need cleaning out as it will be full of oil
hope this helps
John
9/9/2011 9:12:09 PM • Poulan PP4218AV... • Answered on Sep 09, 2011
Poulan 2.1 cu #2150 what is the correct model
On your label you should see the number 2150 plus a type number. There might be another part to the name, such as Predator or PR. You need the entire model to be able to find parts.
Here is the customer service number should you label not be readable or you still can't find it: 1.800.554.6723
or email at www.poulan.com customer service option.
If you find the model and need parts, here is a web address for Milaca Lawn and Garden:http://www.milacalawn.com/parts.asp
They provide parts schematics and fast delivery.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
4/29/2011 12:55:53 AM • Poulan PP4218AV... • Answered on Apr 29, 2011
Sounds loike its running lean, start by replacing the fuel filter on the end of the pipe in the fuel tank, if this does not help you need to richen up the mixture screws, unfortunayly you need a special toll to adjust the screws ( they have a spline, not a screwdriver slot ) the tool is part no. 530035560, once you have the tool unscrew the carb screws 1/2 turn on each and try again.
2/13/2011 6:57:07 PM • Poulan PP4218AV... • Answered on Feb 13, 2011
Chain saw won't start
Before you try to start it, push the primer bubble on the side 3 or 4 times, then pull the choke all the way out. On poulans they can be tricky. When pulling the choke button out, make sure it does not go back in. After you pull the crank rope and you hear it "hit" push the choke back in and pull the crank rope again. It should start after that. If it still won't start, check for a faulty spark plug.
11/15/2010 8:17:56 AM • Poulan PP4218AV... • Answered on Nov 15, 2010
Hello, My pp4218avx starts up cuts for about 5
Sounds like the ignition module. Have you tried replacing that?
11/11/2010 6:08:56 PM • Poulan PP4218AV... • Answered on Nov 11, 2010
42cc 2cycle poulan chain saw does not start spark
Here is a Link to a couple of my Tips. They should solve your problems:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
I don't know anything about outboard motors, so I can't answer the reed valve question. There is a needle valve on the diaphragm side of the carburetor though. Maybe these two parts perform that operation.
Good Luck!
Jim
10/17/2010 2:45:13 PM • Poulan PP4218AV... • Answered on Oct 17, 2010
My 18 Inch chain saw will not keep oiling the
Remove the chain bar and look just below the bolts holding it in place. You'll see a small hole where the chain bar oil pump pushes out oil. Make sure this hole is clear then run the saw without the bar on.
Be CAREFUL of fingers!
You should see oil coming out of that hole. If not, you may need more serious work done with the saw (chain bar pump replacement).
9/2/2010 4:46:31 PM • Poulan PP4218AV... • Answered on Sep 02, 2010
2answers
Constantly stall and has no power
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for condition and replace with original rubber lines, not plastic if needed. Check the carburetor fasteners for tightness including those holding the carburetor to the cylinder. If the two jet screws have not been adjusted, they should be ok. There is a chance that the diaphragm in the lower carburetor chamber is hard, cracked, or has a hole. Also, check the fuel metering valve that the diaphragm controls for tip damage or dirt accumulations. Go to http://www.drystacked.com for a 12 page article on Walbro carburetor theory and troubleshooting which applies to nearly every brand of carburetor used in saws. Hope this helps!
7/22/2010 1:36:55 PM • Poulan PP4218AV... • Answered on Jul 22, 2010
Poulan PP4218AV 18" Chain Saw Logo
49 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
start off switch stuck choke engage
  • Garden
