Poulan Pro 200 Leaf Blower won't start. I have
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
