20 Most Recent Bond Manufacturing 6-pieceUltimate Pruning and GardeningSet Questions & Answers
Extra bolt on top blade of Bond large lopper
It is used to Tighten or loosen the loppers tension. I would not adjust it unless they get really Loose.
10/1/2010 11:22:03 PM • Bond... • Answered on Oct 01, 2010
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
8/27/2008 12:32:13 PM • Bond... • Answered on Aug 27, 2008
2answers
Is weed membrane fabric any good for applying to stone driveway
Ensure the membrane is protected with sand before laying the stone to avoid piercing the membrane.
4/16/2024 10:11:38 AM • Garden • Answered 8 hours ago
How do I found out the valve clearance for a 14.5 I/C OHV. Model 280H07?
Link : https://heavy-equipmentmanual.com/
4/9/2024 7:22:44 AM • Garden • Answered on Apr 09, 2024
4answers
Do I have to prime a 1530 John deer tractor after i replaced the fuel pump?
Yes, use instructions for bleeding after a filter change. See attached.
If primer lever stroke action seems short, bump the starter so the pump cam rotates away from the pump.
4/5/2024 1:18:46 PM • Garden • Answered on Apr 05, 2024
2answers
Strimmer line breaks after a few yards use
buy better line. and chain link fences are ******* lines
4/3/2024 12:50:54 PM • Garden • Answered on Apr 03, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM • Garden • Answered on Mar 31, 2024
2answers
Where can i find choke cable for 422707 model # riding mower.
Do not know what brand that is, but you can find choke cables at lowes, amazon .com. or any number of small engine repair shops depending on where you live. An after market cable could be easier to find and work just as well.
3/30/2024 4:44:30 AM • Garden • Answered on Mar 30, 2024
John deere 310G wiring diagram
3/22/2024 12:08:38 AM • Garden • Answered on Mar 22, 2024
Lawn-boy Insight 10685. How do I get to the drive belt to replace it. I don't have the manual to model 10685.
Question edited for a lot more clarity, add maker, fix typos, change into what I think you were saying. Manuel is the name of a Spanish gentleman, 'manual' is the word you need. Manuals in the link, plus the maker. This link show 'M Series' belt. https://www.manualslib.com/manual/1865101/Lawn-Boy-M-Series.html?page=153
Lawn-boy Insight 10685 Manuals
ManualsLib https://www.manualslib.com > ... > Lawn Mower Manuals and User Guides for Lawn-Boy Insight 10685. We have 1 Lawn-Boy Insight 10685 manual available for free PDF download: Operator's Manual ...
Lawn-Boy Insight 10685 Operator's Manual
ManualsLib https://www.manualslib.com > ... > Insight 10685 This cutting machine is capable of amputating hands See manufacturer's instructions for proper • and feet and throwing objects. Failure to observe the operation ...
LawnBoy 10685 ' PDF ' Lawn Mower ' Motor Oil
Scribd https://www.scribd.com > document > LawnBoy-10685 Form No. 3359-947 Rev A. Insight Lawn Mower. Model No. 10685Serial No. 280000001 and Up. Operator's Manual. Introduction Read this information carefully to ...
Customer Support
Lawnboy https://www.lawnboy.com > customer-support If you need to find a Lawn-Boy retailer, have a question about your mower or want to learn more about its warranty, Lawn-Boy's customer support has you ... ..
3/21/2024 9:57:00 PM • Garden • Answered on Mar 21, 2024
Need Manual for Black and Decker #9443 10" Deluxe Band Saw
yes
3/18/2024 7:12:24 PM • Garden • Answered on Mar 18, 2024
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
  • Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
  • UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
  • Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
  • Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
  • Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
  • Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM • Garden • Answered on Mar 18, 2024
Honda 4514 mower transmission locked. It will not roll in neutral, even if the transmission is released
Hi, I am having the same problem. Were you ever able to get your honda tractor to move? If so, how were you able to do it? Going crazy here.....
3/17/2024 10:21:10 PM • Garden • Answered on Mar 17, 2024
2answers
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
I found my instructions and scanned them. I hope this works for you.d4e90b6d-50a9-49a3-976a-21153b39af82.jpg
3/17/2024 12:09:11 PM • Garden • Answered on Mar 17, 2024
17.5 hp tecumseh oil drain plug
Where is the drain plug on a techumseh Enduro xl/c 17.5?
3/15/2024 11:26:30 PM • Garden • Answered on Mar 15, 2024
Motor runs but blades stopped moving. Not that old oftool
what type of mower. more details on mower required. ride on mower ? push mover ? electric Of Motorized ?
3/15/2024 11:18:55 AM • Garden • Answered on Mar 15, 2024
Where can I find a baumr-ag sx45 0.325 chainsaw cog
usually doing a bit of research on google con bring you up a parts list & suppliers. with the make and model number & then type in either service manual or parts list.pdf. of even a schematic can bring you pictures or websites to help. maybe some scrolling through is needed but you should be in the ball park with this one.
3/15/2024 11:12:06 AM • Garden • Answered on Mar 15, 2024
Victa VRX15538G Ride on Mower. How to replace cutter belt please?
Question edited for clarity and toss in some CAPS. This is exclusively an AUS or NZ machine. We are in North America, so I am hoping this link may work specifically for Victa. The basis is the same for all machines though. https://www.google.com/search?q=victa+vrx15538g+replace+belt ..
3/13/2024 4:02:21 PM • Garden • Answered on Mar 13, 2024
Bond Manufacturing 6-pieceUltimate Pruning and GardeningSet Logo
2 questions posted
Top Bond Manufacturing Garden Experts
Jay Finke
Jay Finke
john h
Are you a Bond Manufacturing Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Bond Manufacturing Garden
Most Popular Question
blade length problem
  • Garden
