20 Most Recent
Milwaukee Tool Milwaukee 10 Amp Recprocating Saw Sawzall Plus with Quik - Lok Cord Questions & Answers
Milwawkee sawzall rotated shaft
If this is an older sawzall there is a bushing in the back plate that aligns the spindle. There is a service fixture for proper alignment. If this is a newer one you have a problem also in the gearcase that would need to be looked at. You can go to milwaukeetool.com and with your model number and serial number download a schematic for this tool . Let me know if you need more assistance and if you do I would need the model and serial number also.
What is Fixya
FIXYA is a technical support site that if you have a problem someone will try and help you or direct you in the right direction to get your problem solved.
I have a milwaukee sspe 1000 qx the brushes have
You can get an exploded view from here
Use only Milwaukee accessories and Milwaukee spare
parts. Should components need to be replaced which
have not been described, please contact one of our
Milwaukee service agents (see our list of guarantee/
service addresses).
If needed, an exploded view of the tool can be ordered.
Please state the Article No. as well as the machine type
printed on the label and order the drawing at your local
service agents or directly at: Milwaukee Electric Tool,
Max-Eyth-Straße 10, D-71364 Winnenden, Germany.
Thanks for using FIXYA
Milwaukee reciprocating saw blade piston turns,
yes it can, probably the spindle or the primary wobble plce I would also check the conition of the front bushings and also the rear. You can go to Milawukeetool.com for a parts exposion on this tool.
Labeled diagram of reciprocating saw
go to Milwaukeetool.com and type in your model number and also you will need your serial number and you can download a wiring diagram and also a breakdown and owners manual for this tool. If I have helped you with your request would you please rate this response accordingly and thank you.
Plugged electric sawzhall in, no power. checked
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Cannot get blade to release
Will the collar on the Quik Lok Turn and if so how much? What you can do is spray some WD-40 on the mechanism to free up the collar, sometimes it gets gummed up from cutting. It should open and close with a snap, hope this helps
Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
6520 chuck problem
Hi, I'm not too struck on using WD40! It cleans down to bare metal and usually adds to the prob. Blow it out with compressed air, moving the chuck back and forth, then add a few drops of 3in1 oil. Try this first before opening a can of worms! LOL Frankster016
Super Sawzall 6527 just stopped working. I did an
could be a couple things, unplug tool and look at the pins on both the cord and the pin housing to make sure none pushed back, next remove handle half and remote electronic and look for a loose flag terminal at the brush holder, look for loose wires on the switch, (give a gentle tug) and remove the brushes and look for unusual wear patterns and possibly a burnt brush spring. Let me know if you need more help.
