20 Most Recent
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Questions & Answers
PE Problem
I don't know of PE as a error for the dishwasher, however stranger things have happened.
Lg has had problems with older units prior to mar 07. They have had wires breaking in the door. If you turn off the power and remove the panel. Look for broken wires and or wires stuck in the insulation. Check for continuity as sometimes it can be an internal break. Fix this and you should be good. Oh put some insulation between before closing it up .
Sgt 48
6/25/2019 5:44:50 AM •
LG 24 in....
Answered
on Jun 25, 2019
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
5/4/2015 4:41:30 PM •
LG 24 in....
Answered
on May 04, 2015
Lg - LDS5811ST Dishwasher OE Error Code
hi
8/17/2013 8:40:02 AM •
LG 24 in....
Answered
on Aug 17, 2013
