20 Most Recent Mtd 22" Yard Machine Push Mower Questions & Answers
Replace the coil
Mtd 22" Yard... | Answered on Aug 22, 2019
You can adjust the shifter go to PartsTreeRepairClinic they will have a video
Mtd 22" Yard... | Answered on Feb 27, 2019
Sounds like one or both of the spindels is going bad the run until they seize and stop the mower
Mtd 22" Yard... | Answered on Aug 26, 2018
No there should not turn the key and it should start
Mtd 22" Yard... | Answered on Jul 12, 2018
PartsTreeRepairClinic clinic will help
Mtd 22" Yard... | Answered on Jul 01, 2018
Either in the tank or on the fuel line going to the carburator.
Mtd 22" Yard... | Answered on Jun 24, 2018
There should be a a tube under the starter motor younhave to push and turn it counterclockwise and take cap off
Mtd 22" Yard... | Answered on Jun 03, 2018
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Mtd 22" Yard... | Answered on May 26, 2018
Parts Tree Repair Clinic they may have a video
Mtd 22" Yard... | Answered on Apr 07, 2018
it has to be spark or no fuel feed remove spark plug lezaving spark plug wire check for spark if you have spark then you know it iseither fuel filter or carburator 9 out of 10 times carb needs cleaning
Mtd 22" Yard... | Answered on Feb 13, 2018
Try taking the fuel jet out and blowing out the little hole that goes through it. Just a little bit of dirt will not let the engine run. While you got the jet out take the fuel bowl off and clean that as well. Be careful and don't mess up the float when you do this as sometimes they are hard to get back in. I find a lot of small engines I get in has a dirty fuel bowl and jet That's all i do in a lot of machines to get them running again..
Mtd 22" Yard... | Answered on Feb 03, 2018
Parts Tree.Repair Clinic may have a video
Mtd 22" Yard... | Answered on Jan 31, 2018
sounds like carb. could use a good cleaning
Mtd 22" Yard... | Answered on Jan 20, 2018
thake out the plug and pull the cord a few times that should clear any oil on the head clean plug and try again if the mower is old the piston rings are either worn or broken allowing oil to get into the fuel .
sounds like you either have a bad fuel filter or your carb needs a good cleaning i would lean to the carb cleaning
Mtd 22" Yard Machine Push Mower Logo
787 questions posted
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
starts right up stalls
  • Garden
