20 Most Recent Yard Machines 158cc Push Lawn Mower #11a 034f200 Questions & Answers
Yard machine 11a-a54e029 manual
SearsPartsDirect or PartsTree.com
2/9/2018 2:19:08 PM • Yard Machines... • Answered on Feb 09, 2018
Mastercraft rear lower plastic guard removal info???
I changed my guard by cutting the rod that is crimped and I got a heavy piece of wire that was the same thickness of the rod and I shoved it through and bent or crimped the ends with vice grips . It works good now. I cut the old rod with bolt cutters but a hack saw will work.
12/28/2017 2:08:46 PM • Yard Machines... • Answered on Dec 28, 2017
What kind of oil do you put in briggs and stratton lawn mower 450
generally, all B&S engines use SAE30 oil, however your local temperature range may make this an unwise choice. Google B&S Oil Chart
10/25/2017 2:38:08 AM • Yard Machines... • Answered on Oct 25, 2017
Need an engine manual not supplied with new mower
GET ON YOUR COMPUTER PUNCH IN MAKE MODEL AND YEAR OF YOUR LAWN MOWER THE SITE WILL COME UP THEN PUNCH IN A REQUEST FOR YOUR MOTOR AND IT SHOULD GIVE YOU A MANUAL YOU CAN DOWNLOAD ON YOUR COMPUTER
9/9/2017 2:46:20 PM • Yard Machines... • Answered on Sep 09, 2017
I RECENTLY BOUGHT A PUSH
i just looked up Quattro mower they are a 4 stroke engine and yes i would buy a 22 inch blade but be sure it fits this mower PS go to wall mart and check out their blades they are reduced now.
9/9/2017 1:59:47 AM • Yard Machines... • Answered on Sep 09, 2017
I have a 4hp yard machine model # 11b504b352 that
Most likely, you will have to replace your carb. diaphragm. Its between the carb. and the gas tank. It collapsed. So the gas is not going from the tank to the carb. as it should be. It will get some gas, but not enough to run right. (Its starving for gas)
5/10/2017 1:30:30 AM • Yard Machines... • Answered on May 10, 2017
2answers
My Briggs and Stratton 300 148 cc lawn mower surges up and down while running. Seems to run best when almost out fuel
You most likely have a partially clogged carb (main jet) and it isn't allowing enough fuel for the engine to run smoothly. This is fairly common. The carb needs to come off, get disassembled, and cleaned paying close attention to the small opening in the main jet.
3/19/2016 10:56:04 PM • Yard Machines... • Answered on Mar 19, 2016
2answers
I let go of the safety handle and it die a little
american mowers are designed to kill the engine,and put the brake on the flywheel if you let the handle go.we in nz,bypass that
4/26/2015 12:15:38 AM • Yard Machines... • Answered on Apr 26, 2015
2answers
My mower only runs full throttle.
The internal govner is a good option.
10/4/2014 2:44:21 PM • Yard Machines... • Answered on Oct 04, 2014
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
9/4/2014 11:06:24 AM • Yard Machines... • Answered on Sep 04, 2014
Carburetor diagrams
need more info. please supply a model and make of engine. example briggs and Stratton, kohler etc
8/14/2014 5:38:55 PM • Yard Machines... • Answered on Aug 14, 2014
Mower isnt running properly. changed the spark
It could be a couple of other things. But the things you have already doe are good!
1. Is it possible that water got in the fuel or fuel tank?This would cause the mower to run rough.
2. You may have a dirt in the carburetor, restricting the gas flow.
3. You may need to replace the gasket and diaphragm ($5.00) in the carburetor. You should do this anyway if you are gonna remove the carb. to clean it.
I'm attaching a Video to help you do this; just click the link::
This carburetor may not be exactly like your, but very close.
Good Luck!
Jim
8/6/2014 10:21:09 PM • Yard Machines... • Answered on Aug 06, 2014
2answers
How to change oil on 158cc briggs
remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
6/11/2014 4:12:37 AM • Yard Machines... • Answered on Jun 11, 2014
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
6/6/2014 1:03:26 AM • Yard Machines... • Answered on Jun 06, 2014
Where safety switches are located on Lesco Commerical walk behind lawn tractor?
Consult your service manual.
5/29/2014 3:49:32 PM • Yard Machines... • Answered on May 29, 2014
Diagram of the retracting spring portion of the flywheel of a lawn mower
Rewind recoil spring? jackssmallengines.com but you will need the engine manufacturer and the corrisponding the number you have provided is for the cutting deck wheels etc
4/13/2014 3:31:06 PM • Yard Machines... • Answered on Apr 13, 2014
0answers
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
159 questions posted
Top Yard Machines Garden Experts
john h
Jay Finke
Jay Finke
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Garden
Most Popular Question
mower will crank will run perfect but
  • Garden
