20 Most Recent Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Questions & Answers
2answers
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
10/2/2023 1:50:07 AM • Troy-Bilt... • Answered on Oct 02, 2023
3answers
Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
9/14/2019 6:12:58 PM • Troy-Bilt... • Answered on Sep 14, 2019
3answers
Have a Troybilt 4 cycle weed eater. checked oil
Owners manual will state proper oil to be used but a good bet is that it requires SAE 30 wt. oil. Check and make sure no cooling fins are clogged with dirt, grease, debris, insect nests etc. Oil helps cool your engine also, but the proper amount is very important. I recommend synthetic oil for engine longevity. It's superior to standard oil for different reasons.
9/11/2019 1:54:31 PM • Troy-Bilt... • Answered on Sep 11, 2019
8answers
Can't get the head off troy-bilt weedeater to replace the line.
Threads are left hand. Hold the black wheel and use large plier or pipe wrench to turn the knob cloclwise
7/2/2019 6:27:53 PM • Troy-Bilt... • Answered on Jul 02, 2019
3answers
What kind of oil does a troybilt 4 cycle engine
sae 30
5/25/2019 6:33:36 PM • Troy-Bilt... • Answered on May 25, 2019
2answers
Trimmer keeps cutting off
change spark plug or like mine it my only use non-e85 gas
2/1/2018 6:34:48 AM • Troy-Bilt... • Answered on Feb 01, 2018
3answers
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
1/31/2018 1:12:59 PM • Troy-Bilt... • Answered on Jan 31, 2018
2answers
The bump knob on my
Believe you may have bad gears in item no. 17 would try replacing. To see this diagram go to partstree.com type in your model no. etc.iplimage (3)-pdt4gccsesyirln1xmij4nvf-5-0.png
10/12/2017 3:59:21 AM • Troy-Bilt... • Answered on Oct 12, 2017
TB575 es 4 stroke -- head won't stop spinning. It's like its on a straight saft to the engine.
Your clutch has failed. Most common reason is a broken clutch spring, but sometimes a shoe will break. To get to your clutch, you need to separate the engine from the shaft at the front face of the engine, NOT where the shaft enters the engine housing.
9/28/2017 10:35:56 PM • Troy-Bilt... • Answered on Sep 28, 2017
2answers
Oil type for troy bilt weeder 4 cycle model #
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
6/16/2017 6:43:09 PM • Troy-Bilt... • Answered on Jun 16, 2017
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." String Trimmer Starts Then Stalls http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered) Toro String Trimmer Starts Then Stalls My String Trimmer Starts But Won Stay Running
6/11/2016 6:27:52 PM • Troy-Bilt... • Answered on Jun 11, 2016
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html Troy Bilt Model TB425CS Parts Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
5/15/2016 5:52:24 PM • Troy-Bilt... • Answered on May 15, 2016
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
12/9/2015 11:52:46 PM • Troy-Bilt... • Answered on Dec 09, 2015
3answers
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
10/3/2015 6:21:46 PM • Troy-Bilt... • Answered on Oct 03, 2015
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
7/3/2015 7:42:14 PM • Troy-Bilt... • Answered on Jul 03, 2015
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
5/15/2015 12:17:08 AM • Troy-Bilt... • Answered on May 15, 2015
Troy-bilt service manual download
Google Troy-Bilt and they should have a link to download a PFD showing the manual.
11/27/2014 3:31:06 AM • Troy-Bilt... • Answered on Nov 27, 2014
How do I change spark plug in troy bilt 4cycle leaf blower
Remove the plug wire boot from the plug and the use a 16 mm. socket to remove the plug. Check the gap on the new plug and install in reverse order.
10/29/2014 1:02:40 AM • Troy-Bilt... • Answered on Oct 29, 2014
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
286 questions posted
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy Garden
  • Troy Garden
Most Popular Question
not keep weedeater running
  • Garden
