20 Most Recent
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Questions & Answers
How do I get a new manual?
Hi Jo Ann....Worx has a variety of trimmer/edgers all
with different model numbers....WG151.5 has been
discontinued...if you can please advise what model
you have.
Regards,
Dennis
I need brackets to mount it to a wall
do a search on eBay for
"garage storage wall hooks"
as for the charger you might need to put it in a bag to hook it up.
that will be the cheapest way.
hope that helps
mark
My Echo GT-200R will not start.
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
Need instructions on changing the spool on
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
