20 Most Recent
Makita 10" Miter Saw LS1030N Questions & Answers
Makita LS1221, started heavy sparking
you need to make sure the brushes move freely in the tubes and if they do I would suspect the armature is bad. LOOK for discoloration in the commutator thru the brush tubes.
Makita LS1030 miter saw, base doesn't rotate as
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
Makita miter saw wontr turn on
make sure that your outlet is hot, once verfied that you have power going to the plug of the saw cord, verify that you dont have any breaks in the cord itself. once verified no issues with cord you can check for power at the switch, if there is power at the switch but not coming on, probably bad switch. If you need further help, reach me via phone at
https://www.6ya.com/expert/allen_b068623c5003aa4b
