20 Most Recent
Miller Electric Mfg Co 903394 Deltaweld 452 MIG Welder, 3- Phase, 15 - 38 V Questions & Answers
Machine is shutting down
yes you have exceeded the duty cycle of the machine, this is a percentage of the continuous weld time
Cooling fan
check voltage going to the fan motor - no volts check power relay or source. also check for volts on the motor name plate and polarity if it has any.no volts means something is not feeding. volts present could mean bad motor.
I am welding thin steel,mig
1. Make sure your drive rolls are the right size, clean and tight. 2. Replace the liner in your mig gun or check end of gun for debris or ****.
Stringy welds
Turn the heat higher and the wire speed lower and you will get better welds...
try to turn the heat up first....
heatman101
I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
