20 Most Recent
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Questions & Answers
Voltage and breaker sizerequired
I am workshop Officer I brought my 250dx from USA Miller tig welding 250 Dx Solve problems Exit Fine of plant in the Pl detail gauid
4/2/2014 7:20:40 AM •
Miller...
Answered
on Apr 02, 2014
How too set up a tig welder for welding thin
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
9/14/2013 10:42:27 AM •
Miller...
Answered
on Sep 14, 2013
Miller welder 330a/bp it will not weld in D/C
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
10/29/2012 10:56:05 PM •
Miller...
Answered
on Oct 29, 2012
Millerbig blue 400 d welder wontstart keep kicking breaker help
1. Make sure a qualified electrician specifically selected and installed your wiring and breaker for this unit.2. Carefully examine all of your power supply connections, wiring, grounding connections (clamps, lugs, and nuts) and cable. 3. Be sure you don't have a steel washer between the grounding lug and the machine power base. 4. You must have a minimum of 4 gauge wiring on your power supply and 2 gauge grounding cable. 5.Take a 3/8" socket and open up the machine and thoroughly examine with a bright flashlight for any electrical burns. 6. If the machine is too dirty to see the components, then disconnect it from the electrical service, lock-out / tag-out the electrical breaker, take the machine outside and wash it down with a hose -- preferably a light duty pressure sprayer and some Simple Green. 7. Let it air dry for 24 hours. Then re-examine.
5/30/2012 10:27:58 AM •
Miller...
Answered
on May 30, 2012
My syncrowave 250 dx has
Use a heat gun to warm suspected parts and isolate the problem. Look for electronic components. Also verify that your torch hose doesn't have a problem. At cold weather they get stiff and may have a problem with wiring. The torch cable is MUCH less likely than a part on the control board. It will take several days to isolate as you will have to wait a day for the unit to cool back to the failed condition. If you can isolate to a smal portion, try using circuit cooler to chill suspected parts back into failed mode.
5/7/2012 6:29:20 PM •
Miller...
Answered
on May 07, 2012
