20 Most Recent Pride Jazzy 1103 Ultra Standard Power Chair Questions & Answers
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Pride Jazzy 1103... | Answered on Sep 11, 2019
hello,i love being of help,im disabled myself.if i help,it would be nice for you to say thanx,but i am not here for prsonal gain,but because i care. Now onto your answer you require,i recently visited shoprider homepage & downloaded a PDF File of a troubleshooter for my scooter also in the troubleshooter was the troubleshooter for an electric wheelchair.it had so many useful tips & depending on what the joystick displayed,that was your guide to solving your problem.you can also print off the troubleshooter for future,try it with yours.& if your not up on computer skills just ask someone in your family.i hope this helped you Colin.
Pride Jazzy 1103... | Answered on Jun 03, 2018
Has the chair been put in "manual mode"? Make sure of this and that batteries are secure.
Pride Jazzy 1103... | Answered on Feb 14, 2018
yellow light is flashing and i can't turn chair off. still operates.
Pride Jazzy 1103... | Answered on May 05, 2017
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Pride Jazzy 1103... | Answered on Nov 28, 2016
Try this
https://www.youtube.com/watch?v=mkCEL5MotSg
Pride Jazzy 1103... | Answered on Nov 03, 2016
a cheep fix is the charger I am showing you from Advance auto it will bolt into stock location and bolt to battery post you will need to make a jumper wire to send batt. voltage to joy stick controller well worth doing the modification to save big $$$$.
Pride Jazzy 1103... | Answered on Sep 09, 2016
They have complicated control computers and are very touchy concerning the amount of voltage in various parts of the system, such as how much current the motor is drawing. Sometimes transmissions go dry of oil causing the gears to bind, throttles develop oxidation on the contacts, terminals get corroded. I had to bypass my original unreliable controller completely with a DC variable speed board from China. Test your batteries by connecting each to their own standard car charger. Get the back wheels off the ground with blocks and test run the motor while connected to the chargers. And test each battery with something powerful that can determine its strength, not just a small test light.
The chargers are reliable, but the control brain (module) maybe not. Make sure your batteries are not dry, make sure fuse is OK, terminals are clean, charging system must be unplugged to run, test test test. Make sure the speed limiter is tried in various positions, parking brake or lock is in correct position.
Pride Jazzy 1103... | Answered on May 13, 2016
Pride Mobility Jet 7 (Power Wheelchairs) - USA Techguide
www.usatechguide.org/itemreview.php?itemid=929
13 posts - ‎11 authors
Anti-Tip Wheels 6&8221; solid; front-mounted • Suspension Limited. ... get either aPride Jazzy, or a Jet 7, you'll be very happy, as long as you can afford a lift ... If youdont, the charge keeps going down, and will not ever recharge back to the ... These products need to be charged about 8 hours a day after usage, so its better ...
Pride Jazzy 1103... | Answered on Dec 01, 2015
Hello,repeat that to a service person.They should be able to give you a price for the job.
Pride Jazzy 1103... | Answered on Oct 29, 2015
Hello,type your issue into YouTube Videos.I am sure you will find what you are looking for.Just remember,if you attempt repairs yourself.Take a Step by Step pic guide,as repair people may not want to look at it.Being you worked on it yourself.
Pride Jazzy 1103... | Answered on Oct 01, 2015
http://www.manualslib.com/manual/134640/Pride-Mobility-Jazzy-Select-7.html . This is the owner's manual. It describes the trouble codes. You can download it to refer to it again.
Pride Jazzy 1103... | Answered on Jun 18, 2015
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
223 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
single red light plus 4 yellow lights
  • Health & Beauty
