20 Most Recent LG LS-L1210CL Mini Split Air Conditioner Questions & Answers
You can down load from www.lg/airconditioner.com
LG LS-L1210CL... | Answered on Feb 03, 2019
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
LG LS-L1210CL... | Answered on Jan 08, 2019
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
LG LS-L1210CL... | Answered on Nov 27, 2018
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
LG LS-L1210CL... | Answered on Aug 08, 2018
good luck with that here
LG LS-L1210CL... | Answered on Jan 25, 2018
You can check LG's website on Air Conditioners that they manufacture at: http://www.lg.com/us/air-conditioners. you may be able to find a number where you can call them for further support. But I would check that website first. Do you know the Model/Serial Number of your unit? This is usually located on a metal piece attached to your unit. Having the correct Model/Serial Number of your product will help narrow your search for manuals to your question.
LG LS-L1210CL... | Answered on Dec 27, 2017
C7-Split compressor over current. Check condenser. If full of dust, clean it. Check rpm of fan motor. If less rpm replace capacitor.
LG LS-L1210CL... | Answered on Sep 20, 2017
Fixya cannot advise sources.
LG LS-L1210CL... | Answered on Aug 13, 2017
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
LG LS-L1210CL... | Answered on Dec 15, 2016
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset Air Conditioning Coral Springs
LG LS-L1210CL... | Answered on Aug 15, 2016
If im understanding, you need a 40va 2 pole contactor
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
LG LS-L1210CL... | Answered on Aug 03, 2016
Thermostat control the room temperature base on it's setting temp.
LG LS-L1210CL... | Answered on Jul 29, 2016
hello,
i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-
1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)
2> then check wheather the wire is in good condition or not means
is it working or not.
3> then clean the outdoor unit filters and coils,
4> and check the proper supply of electricity..
LG LS-L1210CL... | Answered on Jul 04, 2016
sadly no usually only a person that can physically see the unit and what it is or isn't doing can help
LG LS-L1210CL... | Answered on Jun 18, 2016
find an air conditioner service shop in your area as there are non caustic products available to use to clean the fins on the evaporator and condenser
places that sell compressors , driers, evaporators condensers to the air con trade will be the best place to go to
I use a product called viper E+ enzyme power which you spray into the fins of the units and it actively cleans for hours
it is a non rinsing cleaner made by refrigeration technologies part no rt350g
site www.refrigtech.com
not cheap but very effective
LG LS-L1210CL... | Answered on Feb 13, 2016
you can't mismatch capacitors on a unit. cause premature failure of componente in system
LG LS-L1210CL... | Answered on Aug 08, 2015
You need to post/research the model # and brand of compressor. The fan motor will state the UF/capacitor rating. There's absolutely no answer to that ? without more info. Sorry. And sometimes that info is only available from the manufacturer. Most refrigeration parts houses can look it up.
If it lg might have pull down filters in grount of the unit two fingers pull down the middle of the grill botom
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
LG LS-L1210CL... | Answered on Jun 09, 2015
LG LS-L1210CL Mini Split Air Conditioner Logo
342 questions posted
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Steve F
Bill Long
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
uf running capacitor will ok 1 5 ton
  • Heating & Cooling
