20 Most Recent LG LB8000ER Air Conditioner Questions & Answers
manual
LB8000ER Air Conditioner not draing
drain is clogged take the side off unplug drain
7/24/2010 12:03:30 AM • LG LB8000ER Air... • Answered on Jul 24, 2010
My A.C doesn't turn on
cause don't use an extension cord. probably fried the gfi or burnt other wires if you have a meter just test it
6/5/2010 9:39:39 PM • LG LB8000ER Air... • Answered on Jun 05, 2010
2answers
A/C compressor fan won't turn on by itself.
there is a problem with your fan i'm sure. change the bossing of your fan it will work good.
5/11/2010 11:17:57 PM • LG LB8000ER Air... • Answered on May 11, 2010
My motor compressor thrifts every 5 mins.
If you have a low pressure switch on your air conditioner it's opening and closing, because you don't have enough refrigerant in the system or it's cycling on the thermal overload in the compressor because it's getting hot.
You need to charge your system to approximately 12° to 15° superheat not by pressure.
3/26/2010 2:26:48 AM • LG LB8000ER Air... • Answered on Mar 26, 2010
Ac doesn't throw cold air
hello friend, All the compressor work in above 190 v. please additional fitting in voltage stabilizer okkkkk
6/24/2009 6:07:00 AM • LG LB8000ER Air... • Answered on Jun 24, 2009
Air conditioner not working properly
You can pull the inside of the unit out of the case to inspect the back coils mainly to see if there is any blockage. Note the screws on the bottom of the housing the holds the coils take the screws out and very gently take the coil and move out a little. It will flex enough to clean the coils. Just don't hit it with very high pressure water cause it will bend the fins that go around the coils. I have done a bunch of window units this way and you would not believe the difference it makes. Let unit dry out and re-assemble. Let me know if you need anything else.. ken
5/27/2009 2:58:54 AM • LG LB8000ER Air... • Answered on May 27, 2009
Air not cold
If you are always using it, yes it could be. The heat it produce helps in its normal wear and tear. Corrosion is one and dirt helps. Freon could stay in the system as long as it is not getting any break or hole.
If freon is out of the case. Unit not getting cold, the fault could be dirty air filtter, dirty exchanger, dirt in the system itself, or clog. And also you cannot negate it thermostat, could be its setting or actually faulty. And compressor fault.
5/22/2009 4:45:37 AM • LG LB8000ER Air... • Answered on May 22, 2009
2answers
Air Unit turns on...compressor works, fan turns on and then shuts off?
Let me guess you drove it home on its side in your back seat and then plugged it in? Or like many stores with a surplus of product and limited space, there are some units that are stored on their sides by idiot employees, or ones that don't care they just want to get the freight put away. All of which will more than likely result in a dead air conditioner, refrigerator, or dehumidifier if the unit is not upright overnight before use. The refrigerant is also acts as the lube for internal parts and when stored improperly will all be located in the coils, and not in the compressor where it needs to be. You plug it in and the unit will overheat and die. Either that killed it or it was DOA, go back and exchange it. Why bother troubleshooting something you can exchange? If you did drive it home on its side don't tell them that, unless you are that guy who didn't put 50:1 in his lawn mower. Hack
4/21/2009 9:03:37 PM • LG LB8000ER Air... • Answered on Apr 21, 2009
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
8/18/2008 9:15:06 PM • LG LB8000ER Air... • Answered on Aug 18, 2008
Electical
if its electronic controls verify the fuse if it's manual controls the selector switch shorted out.
5/9/2008 10:31:33 PM • LG LB8000ER Air... • Answered on May 09, 2008
Unit filled with water -hard to drain
possibly its a capacitor thats faulty and not the drainage. still, the unit will have to be removed from its casset (case) to be repaired.
10/23/2007 2:28:04 PM • LG LB8000ER Air... • Answered on Oct 23, 2007
New AC thermostat setting creeps up when running the Timer Mode
This should be checked by a professional because several things could cause this.  The good news is that it is under warranty for in home service.  If you live in the US and need help finding someone for service let me know.  Would appreciate a solved rating if you have no further questions.
10/13/2007 3:41:17 PM • LG LB8000ER Air... • Answered on Oct 13, 2007
2answers
Air conditioner is not blowing cold air
it has very low amount of freon left. best economical decision is replace unit.
6/27/2007 11:49:21 PM • LG LB8000ER Air... • Answered on Jun 27, 2007
4answers
My LG air conditioner is saying water fl what is that and where can I find it? I cannot find the book.
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain. Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service. Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps. Cindy Wells
4/23/2024 5:57:52 AM • LG Heating &... • Answered 2 days ago
CH21 error on LG - 800 Sq. Ft. 14,000 BTU Smart Window Air Conditioner (model LW1522IVSM).
The error is that the DC voltage is too high, not the house AC voltage. It should regulate through a transformer. Get LG to send an engineer under warranty. If you have a multimeter, you can test your house voltage. DC peak error / IPM fault; compressor DC voltage was too high.
DEFINING COMMON ERROR CODES
LG HVAC https://lghvac.com > resource-service > filename=... PDF DC peak error / IPM fault; compressor DC voltage was too high. 2X. 1X. 22. Current transformer2 (CT2) error; AC input current is too high. 2X. 2X. 23. DC link ... https://www.google.com/search?q=LG+AC+CH21+error ..
3/31/2024 6:42:12 PM • LG Heating &... • Answered on Mar 31, 2024
2answers
I have error code ch 09 displaying on my
The error codes are not all the same. They are different for different models.
THIS IS NOT A SOLUTION....
This is a "Clarification request"
Can you please locate and post your LG model number here so we can help you properly and professionally.
1/19/2024 10:12:44 AM • LG Heating &... • Answered on Jan 19, 2024
2answers
LG air conditioner
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Also What is the model of your air conditioner. With out that information i cant help you with your ac repair problem Check us out online at AC Service Delray Beach Fl
1/17/2024 7:36:35 AM • LG Heating &... • Answered on Jan 17, 2024
2answers
I have a LG air conditioner which seems stuck on defrost. It works fine in cooling but when on heat the defrost light comes.
Possibly a stuck or closed defrost sensor. The sensor gets to freezing which closes the switch. So the unit goes into defrost cycle which switches the flow of the freon on a Heatpump. The hot gas thaws the coil and the sensor. Which opens the switch and switches it back. I'm giving this answer without knowing more about the unit. Defrost light comes on & it doesn't run at all? LG system is a split unit or window unit or what? If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
11/20/2023 9:45:38 AM • LG Heating &... • Answered on Nov 20, 2023
LG LB8000ER Air Conditioner Logo
15 questions posted
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
air conditioner not working properly
  • Heating & Cooling
