20 Most Recent Spa Parts Plus GFCI, Circuit Breaker, 30 Amp Questions & Answers
0answers
My older f series hot springs spa trips the heater
I would check to make sure thats what this calls for could be weak breaker
4/17/2010 3:26:05 AM • Spa Parts Plus... • Answered on Apr 17, 2010
I have a Hotsprings Grandee tub. I drained and
Probably a ground Id check that water did not get into any ele.system
4/17/2010 3:15:59 AM • Spa Parts Plus... • Answered on Apr 17, 2010
Need electrical diagram on connecting gfci to
This can be confusing, but basically, you will need to get a hot wire to the GFI receptacle. If you get a wire from a switch, you need to splice into the hot wire - not the other one (which is a switch leg). You will also need to get a neutral wire to the GFI recept. You normally won't find this at a switch, because you never run a neutral to a switch. The only exception is when there's a light on the switch itself. But let's not get confused with this. There's no neutral at a switch. So your best bet would be to get your hot and neutral from another receptacle. Or, you can get your hot and neutral wire from your electrical panel. Its very important that you do this correctly, otherwise you can cause other problems. I hope this helps you out a little. If you have more questions, feel free to contact me. Good Luck to you, and I hope this works for you. - Jim
4/5/2010 4:45:23 AM • Spa Parts Plus... • Answered on Apr 05, 2010
What is required wire size from the main panel to
if it is a 30 amp 220 you will need #10 wire, if 40 amp then #8 wire
12/27/2009 10:03:54 PM • Spa Parts Plus... • Answered on Dec 27, 2009
3answers
How to wire up a spa or jacuzzi
Breaker, even GFI's are designed to trip at 135% to 600% over there load rate, so not to scare you but it depends more on the wire used from the main panel to the dryer/hot tube then the breaker. A GFI's claim to fame is the speed at which it will trip if voltage is detected on the ground side of the breaker. So to answer a question with a question, Can you overload a GFI without tripping it, Yes you can, just be careful the life of your hot tube motor and heater could be in danger if you overload the circuit.
12/27/2009 6:16:22 PM • Spa Parts Plus... • Answered on Dec 27, 2009
Hello i have a spa and i just installed a 60 amp
generally applliances, like refidgerators heaters, anything with motors don't like gfci's... or gfcis don't like them. take out the gfci breaker and you should be swirling in no time,... when's the party?
12/13/2009 2:47:07 PM • Spa Parts Plus... • Answered on Dec 13, 2009
50 amp GFCI breaker trips after spa runs for 45
More than likely, it's the element. They begin to 'leak' small current as they get old and this will trip the GFCI If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
7/11/2009 7:39:45 PM • Spa Parts Plus... • Answered on Jul 11, 2009
Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
6/28/2009 1:09:44 PM • Spa Parts Plus... • Answered on Jun 28, 2009
GFI 'shorted'
load neutral connects to the neutral binding screw on the GFI, do NOT connect the load neutral to the neutral bar.
5/28/2009 3:09:25 AM • Spa Parts Plus... • Answered on May 28, 2009
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
3/24/2009 9:28:11 PM • Spa Parts Plus... • Answered on Mar 24, 2009
2answers
30 amp 2 pole GE GFCI breaker pops on hot tub after hrs of use
I have seen circuit breakers trip at a lower amperage. It seems that they are weak. Generally circuit breakers run with 80% load with no problem, in your case 24 amps. I would replace the circuit breaker.
1/12/2009 2:21:17 AM • Spa Parts Plus... • Answered on Jan 12, 2009
0answers
0answers
0answers
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Spa Parts Plus GFCI, Circuit Breaker, 30 Amp Logo
17 questions posted
Top Spa Parts Plus Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Spa Parts Plus Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Spa Parts Plus Electrical Supplies
Most Popular Question
hotsprings grandee tub drained
  • Electrical Supplies
