20 Most Recent LG DLE2514 Electric Dryer Questions & Answers
My dryer had this same problem. I cleared it by unplugging the dryer from the wall for 20 seconds and then plugging it back in. After this "reset" of the electronics, it has functioned for 2 days without a problem.
LG DLE2514... | Answered on Apr 01, 2019
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
LG DLE2514... | Answered on Jan 05, 2019
The breaker won't reset? Or the dryer? If it.s the breaker, it is protecting you from a short circuit and a possible electric shock. Are you sure you want to try to fix this without a professional?
LG DLE2514... | Answered on Feb 06, 2018
Is it a mechanical timer you turn (the "clickety-clank"-kind) to set the time? Sounds like something in it has been worn out. Shouldn't be too hart to get a replacement for it,t and you should also probably be able to replace it yourself unless you're very "un-handy", or want to play it safe.
LG DLE2514... | Answered on Jan 07, 2018
The cooling light stays on so that is not the issue. Check to make sure you have power in both hot legs of your 220v power outlet.
LG DLE2514... | Answered on May 16, 2017
Turn off breaker wait an hour turn back on.
LG DLE2514... | Answered on Dec 15, 2014
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
LG DLE2514... | Answered on Nov 06, 2014
If you're talking about the moisture sensor, it's located in the lint filter casing. Remove your lint filter and look inside the casing. About 4 to 6 inches down on the right-hand drum side of the casing and running to the center, you should see two flat metal arcs following the contour of the casing. These metal arcs are the moisture sensors
LG DLE2514... | Answered on Aug 29, 2014
Check the thermal fuse, start switch on the control panel and door switch because all three are more likely the cause of the dryer not starting up.
The door switch is often the culprit in this type of fault, although a faulty drive motor is not ruled out.
LG DLE2514... | Answered on Jul 05, 2014
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
LG DLE2514... | Answered on May 30, 2014
There is a switch on the motor that could be bad or restricted with excess lint build up.
LG DLE2514... | Answered on May 03, 2014
LG DLE2514 Electric Dryer Logo
328 questions posted
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dryer work check filter light
  • Dryers
