20 Most Recent
LG WM1814CW Front Load Washer Questions & Answers
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
LG WM1814CW...
Answered
on Jun 29, 2018
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
LG WM1814CW...
Answered
on Jan 09, 2018
Our LG Tromm WM1814CW frontload
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
LG WM1814CW...
Answered
on Dec 14, 2017
What do I put in the machine for the tub clean cycle?
john low temperatures washing can cause the machine to smell
if it was me i would set the machine to it's hottest wash and use a descaller or bleach and washing liquid ,after wash has finished give it an extra rince cycle./ scrum around rubber seal behind door before starting wash. check pump filter is clean,
LG WM1814CW...
Answered
on Sep 24, 2016
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
LG WM1814CW...
Answered
on Apr 20, 2016
When draining the machine makes noise
If there is a back panel on the machine you can access it from there, if it has a enclosed back then you will have to lean the machine backwards against the wall to get underneath to access it. The pump has two wires attached to it make sure the power is off & lead removed from wall before you unplug them otherwise you get zapped. The drain pump is held into the pump casing/housing by three Phillips head screws. Undo the screws remove old pump and replace with new pump, make sure rubber seal is on the new pump before installing. You will need a torch & a Phillips head screw driver.
LG WM1814CW...
Answered
on Sep 30, 2015
