20 Most Recent
LG WM2277 XL Front Load Stackable Washing Machine with 7 Washing Programs in 3 Colors .... Questions & Answers
LG WM2277
OE(outlet error). Your drain pump is stuck. Remove it and check what the obstruction is. Reinstall and test.
What does oe stand for on a LG washer
Hello. OE on an LG washer is telling you it cannot drain. Start by opening the small panel on the bottom left of the washer and checking the drain screen/trap. If the washer is full of water you are going to need to removed the water from the tub by taking the small capped hose located in the same compartment, remove the hose cap and drain into a bucket. Afterwards remove the trap and check it for debris. If it is full of debris, clean it and install. If there is nothing in the trap, then you likely have either a jammed up pump ( bobby pins are notorious for this) or a failed pump that will need to be replaced.
LG washer makes scary noises during spin cycle
That is the sound of the bearings going out. If you want to do the job yourself I can direct you to the parts you will need. They will cost around $50.00. If you call a repair service out, look to pay $250.00 or better to fix it.
Drip tray for LG washer
all washers will leak for one reason or other / eather over load or shaking or something so be safe and get a pan that will fit and save your floor and ceiling
Overload in motor noted as LE
frenchie, the LE has to do with the motor sensor, There should be a 3 pin connector in the motor harness that connects to the stator. It could of come loose, or the sensor itself gone bad. The other scenerio would be the sensor harness to the main board had opened or came loose. Since this machine is under warranty, you wouldn't want to void it. You can try to put it into the self test by doing the following: Turn the unit off. Press the spin speed and soil level buttons together, while holding them, press the power button. The buzzer should sound twice. Now by pressing start/pause button you can advance it through 12 tests. Everything from slow tumble, spin, inlet valves, circulation pump, drain pump. The 12th being door unlock and power off. I don't know if this will work or not but it's a chance to get you going again until factory service can get out there....Catriver...post back.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
