20 Most Recent
LG WD-3245 Front Load Washer / Dryer Questions & Answers
My washer lg wd-3245rhd will
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
When i plug washer in,cl
There is no "cl" error code for the LG WD-3245RHD. Your display unit may be bad, because there is a "cE" error code, which indicates an overload in the motor, and the suggestions in the manual are to close the tap, unplug the machine and call a service technician. So far, I have been unable to find anyone that will adequately service any LG appliance. It seems they think of their products as disposable, not repairable.
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Unit will not turn on at all
Sounds like the problem is with the control board. There is an internal fuse in the board but it is not replaceable. You will need a qualified LG technician to service this unit.
