20 Most Recent LG WFT1071TP Top Load Washer Questions & Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. If all this does not work, check your pump for blockage.(ref manual re pump)
Rate me pl.....if helped.
LG WFT1071TP Top... | Answered on Jul 14, 2019
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
LG WFT1071TP Top... | Answered on Apr 25, 2019
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
LG WFT1071TP Top... | Answered on Dec 29, 2018
Lid lock failure. Replace lid lock
LG WFT1071TP Top... | Answered on Sep 12, 2018
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
LG WFT1071TP Top... | Answered on Sep 04, 2018
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
LG WFT1071TP Top... | Answered on Aug 21, 2018
BELOW ARE STEP BY STEP RECOMMENDATION ON HOW TO SOLVE THE PROBLEM OF YOUR WASHER THAT HAS FAIL TO WORK AS EXPECTED.
However,if you are having problems with either not draining or spinning, with your front load or top load washing machine, then you need to realize that they can be interrelated. Mostly in that if your washer is not draining the water it will not spin at all or at least not properly. There also can be others problems that will stop or slow down the spin, but the water not draining is the most common one.
So, if you are stuck with a washer that is full of dirty stinky water then here are some things to start checking.
First get that shop vac out or a bunch of rags and a bucket. The water needs to go. The shop vac will pull the water out the drain hose. Just remove it from the standpipe and place the nozzle in the hose and pull the water through the pump and into the shop vac. Of course if you cannot pull the water out this way, you already know that the pump is blocked or clogged, then just vac out all the water you can from the inside of the washer.
If all else fails, remove the front cover and take off the hose going from the tub to the pump. Yeah, water will go all over, but that is what the rags and bucket are for.
When the water is gone, you can then pull all the stuff out of the hose and pump, that are causing the problems. Most of these pumps are very easy to take apart and clean out. This will make sure that there isn?t anything inside the pump that can stop it. They are not very strong motors and something like a toothpick may stop it.
Now, where this get tricky is that there are sensors that check the water level and adjust the spin. If your water is not draining, your washer will not spin either.
For many washing machine problems that are drain and spin related, this simple cleaning will solve your problem. But there are other possibilities.
The lid switch is the old problem that keeps raising it?s ugly head on all washers. Bottom line here is that if the washer thinks that the door is open, the things don?t work right. Check out the door switch to make sure it is operating properly.
Make sure the new front load washers are on a good solid level surface. If the machine can move around then the sensors will often sense the movement and not allow the machine to reach full spin speed. Some manufactured bases may not be stable enough to give correct readings to the machine. If your washer is moving around, then fix that problem.
The timer can also be a problem. Many will wear out and then get to a point in the cycle, then not advance any further. Also the computer controlled sequencers can also get glitches and may need to be reset. You can check out the timer by manually advancing it, and the computer reset procedure will be in your manual that you received with your washing machine.
By going through this check list you can check out the problems that most handy persons can handle in the home. To make sure you have a the best chance at a trouble free washing machine, make sure that you do not leave anything et into your washer that will cause it harm or plug it up.
Good luck and thanks for using fixya.
LG WFT1071TP Top... | Answered on Mar 31, 2018
The water level switch is always at the top of the machine. All it is is a tube that goes from the bottom of the drum to the switch. The water rising cause air pressure to increase in the tube and it presses on a diaphragm, which pushes a micro-switch. It is round and slim, with one pipe and two wires. It is either fixed to the case inside at the rear, or hiding in the console. See the videos. Sometimes the pipe splits or leaks air, so you need to test the switch. Make sure you unplug it.
water level switch located on the LG fuzzy logic Google Search
LG WFT1071TP Top... | Answered on Feb 21, 2018
Remove the top of the washing machine cover to access thehot and cold water solenoids. Disconnect power to the washer and wioe clean around the the manifold. See where leak is coming from . it could befrom the solenoid valves threads.
LG WFT1071TP Top... | Answered on Nov 25, 2017
try let washer with notting in it go threw a wash cycle see that want clean it out if it dont then you might want call a appliance repair tech
LG WFT1071TP Top... | Answered on Oct 21, 2017
where can I find a display board for my lg wf-t1233tp top loader washing machine
LG WFT1071TP Top... | Answered on Sep 10, 2017
How old is the washing machine?
LG WFT1071TP Top... | Answered on Jun 18, 2017
There really is a sensor magnet that is necessary for door lock mechanism to work. Not sure about service call charge, but if it works the he did fix it anyway
LG WFT1071TP Top... | Answered on May 20, 2017
LE error is hall sensor is bad or bearing not letting motor turn
LG WFT1071TP Top... | Answered on Feb 23, 2017
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
LG WFT1071TP Top... | Answered on Jul 02, 2016
try any dealer selling that MAKE unit .
LG WFT1071TP Top... | Answered on Jun 19, 2016
drain out pump is in the open position ,due to some object is struck at the mouth .remove drain out pump and re fix.
LG WFT1071TP Top... | Answered on May 01, 2016
LG WFT1071TP Top Load Washer Logo
611 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
using lg fuzzy logic 6 5kg wf s6607tc
  • Washing Machines
