20 Most Recent LG WD-1280FHD Front Load Washer Questions & Answers
LD combo WD ( DirectDrive WM3431HW), starts the
sound over load in motor
9/26/2018 3:03:12 PM • LG WD-1280FHD... • Answered on Sep 26, 2018
Hi I have an LG
Hi Matt Ask your mechanic to change the door hingle only. Dont change the complete door.
2/18/2018 12:56:29 PM • LG WD-1280FHD... • Answered on Feb 18, 2018
Lg Washing machine. WD11020D will not open.
door lock sounds like its broken, you will need to remove the two screws on the back of washer top and remove the top. (power off) now as you look at washer from the front you will see a round object with a pipe. remove the pipe and see if the door opens. this is just to check to see if its this part stopping the door to be open, you are going to need to use a flat blade to push the pin in the lock you should see the pin as this stops the door from being open. the part looks like this https://www.ebay.com/i/253266384384?rt=nc if the door is slammed or banged, it can damage the lock, easy to replace when the you can open the door. wiring plug only fits one way.
12/7/2017 3:27:10 AM • LG WD-1280FHD... • Answered on Dec 07, 2017
8answers
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
10/8/2015 3:46:59 AM • LG WD-1280FHD... • Answered on Oct 08, 2015
2answers
Removal of the bearings
Those bearings are almost impossible to remove.  You would be better off replace the rear half of the tub assembly as it comes with everything.
9/22/2015 4:50:29 AM • LG WD-1280FHD... • Answered on Sep 22, 2015
LG WD-10485TP PROBLEM CL
not work can you tell me an other method if you know
8/27/2015 3:43:12 PM • LG WD-1280FHD... • Answered on Aug 27, 2015
WHAT CAN BE THE PROBLEM
WATER INLET VALVE
3/30/2015 7:52:55 AM • LG WD-1280FHD... • Answered on Mar 30, 2015
3answers
Error code PE on top loader(LG)
Check the pressure switch -the system that determines correct waterlevel in the drum. If its giving an incorrect indication to the programtimer machine will either overfill, refuse to fill or refuse to spin.Its an air operated diaphragm switch triggered by rising air pressureinduced by the entry of water into an airtight vessel attached to thebase of the drum. It tells the program timer that the water has reachedthe correct level, allowing it to proceed to the water heating stage inthe cycle. Power off, drag machine out onto the floor, remove backcover and top cover. The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. It generallysits just under the top cover. Disconnect the thin rubber pipe from theswitch and blow down through it to clear any blockage. Switch itselfmay be faulty but its more likely the pressure pipe or the vesselattached to the other end of the pipe is blocked. Some machines havethe pressure vessel integrated as part of the filter unit, with apressure chamber moulded into the top of the filter body. Remove thepressure vessel, put a small nut or screw in it, fill it with water andshake vigorously till any crud or residue is removed. Refit all parts,check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at thefoot of the machine.Some are obvious like little square hatches andsome are hidden behind the trim panel at the foot of the machine. Oncepanel is removed the filter should be visible. Its generally a circularplastic fitting which unscrews in an anticlockwise direction. Somehotpoint, indesit and ariston filters are located in the big black sumphose (the one that leaves the bottom of the outer drum and connects tothe pump). Power off, drag machine out onto the floor, remove backcover or tip machine up at an angle. Locate sump hose, remove thetensioner clip by squeezing the tabs together with a large pair ofpliers or vise grips, remove the hose, take out filter and clean. Beprepared for spillage of water. May help if the machine is tiltedbackwards at an angle.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
11/16/2014 4:18:49 AM • LG WD-1280FHD... • Answered on Nov 16, 2014
2answers
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
7/31/2014 1:54:23 PM • LG WD-1280FHD... • Answered on Jul 31, 2014
0answers
0answers
0answers
How do i repair start/pause button
you dont try to repair it if you do it your board may be comletely or partially gets damaged which may cause malfunctioning so u better contact to your near lg store
6/5/2014 4:20:20 PM • LG WD-1280FHD... • Answered on Jun 05, 2014
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
4/11/2014 11:52:39 PM • LG WD-1280FHD... • Answered on Apr 11, 2014
173 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
washing machine doesnt wash
  • Washing Machines
