20 Most Recent LG WD-1041WFH Front Load Washer Questions & Answers
Main lights bleeping, drum not spinning
try unplugging from wall and replugging back in in a minute or two. good luck.
11/28/2015 12:34:35 AM • LG WD-1041WFH... • Answered on Nov 28, 2015
0answers
0answers
2answers
The door is jammed on my LG Intellowasher
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
8/13/2012 2:51:53 PM • LG WD-1041WFH... • Answered on Aug 13, 2012
0answers
Water not draining from the
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
8/19/2010 3:20:35 PM • LG WD-1041WFH... • Answered on Aug 19, 2010
Hi i need an instruction manual for an LG
If you google the brand and model you will get a lot of info and/or a locality where you can request a manual....Good luck.........Nomess
4/21/2010 12:01:29 AM • LG WD-1041WFH... • Answered on Apr 21, 2010
2answers
I have this LG WD-1041W. Lately \r\nit is pumping
Follow the below Guide :-
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/17/2009 2:42:19 PM • LG WD-1041WFH... • Answered on Nov 17, 2009
Operating instructions for a wd 1049c washer
go to lg's website and put in your model # and you can download the manual
6/21/2009 1:41:28 AM • LG WD-1041WFH... • Answered on Jun 21, 2009
I have LG washer wm2016cw got OE code. I am attempting to remove the drain pump filter. I removed the drain filter cap, but the filter is did not come out. Is their a trick to get the filter out.
To remove the drain pump filter on your LG washer model WM2016CW, try gently wiggling and pulling it after removing the cap. If it's stuck, apply lubricant sparingly and tap around the edges. Comparing with your mother-in-law's similar model might offer insights. If all else fails, refer to the manual or contact LG support for assistance.
4/11/2024 4:51:23 PM • LG Washing... • Answered on Apr 11, 2024
LG Fuzzy Logic 8.2kg WF-8071TTP washing machine doesn't dissolve the soap and leaves marks on the clothes.
You are using the wrong type of detergent. Use liquid instead of granulated powders. They don't dissolve in low temperatures. https://www.manua.ls/lg/wf-8071ttp/manual?p=8 ..
4/7/2024 7:25:34 PM • LG Washing... • Answered on Apr 07, 2024
A new LG dryerDLE7150W. It will run for 10 minutes then shut off and have a nP code. checked everything from the panel to the cord connections and it is good.. I have 221c at the outlet. any clue?
An nP display code indicates that there is a problem with the electrical wiring in the home and that no current is being detected at the heater.
2/8/2024 3:03:16 PM • LG Washing... • Answered on Feb 08, 2024
I have a LG WM2688HWM washing machine with a spin problem.
This has a new fangled direct drive motor. Normally the fix would be to replace the motor controller or one of the capacitors on the board, but this has none of those, and appears to be run by one control board and that is no longer available. Try cleaning the connectors to the control board with electrical switch cleaner spray. Your best bet is to call for service and hope they can replace the part that is preventing the spin cycle. https://www.searspartsdirect.com/model/1nx1gwawbm-003204/lg-wm2688hwm-washer-parts Some videos on that issue ..
2/1/2024 4:26:00 PM • LG Washing... • Answered on Feb 01, 2024
LG WD-1041WFH Front Load Washer Logo
23 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
operating instructions wd 1049c washer
  • Washing Machines
