20 Most Recent
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Questions & Answers
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
How do I stop the front loader (washer/dryer from flooding my rv?
If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
If the pressure switch is fine, check the water inlet valve for continuity on the solenoid coil by removing the top cover of the machine.
Change board LG washer
Screws for the lid are at the back, normally only two. Then push lid towards the front to release lid from the two clips. assess...ame
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
