20 Most Recent Makita HM1800 64 lb. Breaker Hammer AC/DC Questions & Answers
As the retainer shaft (part # 322550-8) wears it will begin to drop the bit. Also could be the roll pins that hold the shaft. Remove the two pins and take a look at condition. You could build up the metal with welder and grind to shape. Part is available at www.toolpartsdirect.com at a cost of about $25. Good luck with your repair.
Makita HM1800 64... | Answered on Jul 08, 2010
you have a armature problem I would think, look into the brush tube and try and spin the armature and look for discoloration on the commutator bars.
Makita HM1800 64... | Answered on May 24, 2010
Makita A-90582 or (the equivalent)
Hitachi 981840 Hammer Grease
But dont forget to replace all o-rings and seals at the same time some older models have special wear tear parts sets for service also called maintenance spare parts. If the brushes are short then its time for service.
Makita Hammering | Answered on Dec 02, 2019
254031-3 pos14 part inlay key can be damaged pos 11 drive rod 315146-2 can broken IF mechanical damage or dried out by leaking gasket / orings.
For better repair use after a repair of some parts an maintenance kit 193394-1 If the working hours are on it, but also after an repair on other parts because leaking tools can be dried out and give cured o rings in a very short time by building up overheat temperature inside and will not build up pneumatic power it will not do the job and is not good for physical strain.
Makita Hammering | Answered on Oct 02, 2018
The GREASE for this heavy jackhammer
Makita 181490-7 Grease (if there are short carbon brushes to find ) replace all orings gaskets (and looking for an maintenance kit for this machine) 188015-8 thats the better way to service.
Makita Hammering | Answered on Sep 12, 2018
Connecting rod
Part Number:
315419-3
or
Woodruff Key 4
Part Number: 254001-2
Makita HM1211B Parts List and Diagram eReplacementParts com
Or broken spindle/ worn bearing(s)
Makita Hammering | Answered on Aug 12, 2018
burning motor
take it in for a check or junk it
Makita Hammering | Answered on Jul 07, 2018
Order an maintenance kit for it , when the working hours are on the tool , all given parts in the kit must be replaced its not a good idea to only grease it, the tool should not leaking by the chisel. then there will be a bad break-force and give a long working job..
Makita Hammering | Answered on Mar 01, 2018
first ordernumber 931848 lubrication necessary it has its working hours on it.
parts to change in priority
1 x 944-927 , 949457Z , 956-960 , 944-936 , 956-965 ,
999032 , 956-996 , 944-928
the important thing is that the machine is airtight at the front so as not to burn the O-rings through the air and incoming dirt friction look the orings good and if the lock bolt on the front feel not smooth replace that also and every oil seal you can find its different what should neccesary but that the tool runs with thick and dirt beaten oil . solvent clean the hard metal parts and replace if there are grooves on or cracks
Hitachi PH 65A Demo Hammer Parts
Makita Hammering | Answered on Mar 17, 2016
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Makita Hammering | Answered on Mar 16, 2016
something broken , or only dry, leaking (o-rings hard or burned inside) or the armature drive is worn .
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
193606-2 its the neccesary service kit for the tool with all the parts but be aware to control the locking sleeve and impact bolt replace it if its not air tight
As long as its last and the endurance of the worker in first place .
Its better then use rotating hammers at a long lasting working order , because of the price the choice of a demolition hammer is always a great difference because of the time you can spend , there are much Chinese models look a like this hammer its popular also bosch models you will see .
chinese demolition Google zoeken
Makita HM1800 64 lb. Breaker Hammer AC/DC Logo
7 questions posted
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
View Most Popular
Makita Hammering
  • Makita Hammering
Most Popular Question
bit not lock in place just falls out
  • Hammering
