20 Most Recent Apple iTunes Questions & Answers
open Google search engine and write free applications with the model of your brand .
you will get the all links from which you can download free applications.
Apple iTunes | Answered on Nov 20, 2019
Right click on it and select run as administrator. if that doesn't work.
Remove itunes from add or remove programs, do a search for itunes on your harddrive and delete all folders with itunes or apple on it. there are probably some files in documents and settings folder that need to be removed.
basiclly the itunes and apple software needs to be fully removed and then reinstalled.
Apple iTunes | Answered on Nov 08, 2019
Visit
Welcome to Apple Support . Scroll down and click on "Contact us". Click the blue "Get Started" button. Click on "iTunes" then "iTunes Store". Choose your reason for contacting them. Most common is "Purchases, Billing, & Redemption". If your sub-topic is not listed, click on "The topic is not listed". In the entry field, briefly explain the issue you are having. Try to be descriptive. Then click "Continue". The next page always has an option for email. If chat is open & available that option will appear there as well. This gives you access to the people at Apple with the ability to handle iTunes Store account and purchasing issues. You will not find someone on the phone with direct access to your iTunes Store account.
I’m happy to help further over the phone at https://www.6ya.com/expert/clint_f00dc48f472715e0
Apple iTunes | Answered on Oct 01, 2019
In order to fix this problem, go to billing info, and when it lets you choose the credit card method, choose the option "none" then it will let you use your gift card. Otherwise it assumes you want to use a credit card. Hope this helps.
The only way that can happen is someone has accessed your account, got personal details from you. Contact your bank, plus contact iTunes to see where they have got your personal details from and when it happened.
If you have an account, billing, or purchase question, send our iTunes Store support team an email using this form.
Hi David,
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer.
The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod.
How to Delete Music from iPod in Batch
Apple iTunes | Answered on Sep 16, 2019
To create your iTunes Store account:
  1. From inside the App Store or iTunes Store tap Sign In at the bottom of the page.
  2. When the prompt appears, tap Create New Account.
  3. Choose the appropriate store by tapping on Store, and select the country in which you reside. Tap Done to confirm your selection, then tap Next to proceed to the next screen.
  4. The next screen will display the iTunes Store Terms and Conditions. You can opt to have the Terms and Conditions emailed to you for easier reading by tapping Send by Email. Enter your valid email address then tap Send.
  5. After you've read through the Terms and Conditions tap Agree, located in the bottom right of the page. Then again when the confirmation appears.
  6. Once you've agreed to the terms and conditions, you'll need to input your preferred email address and password along with answers to some security questions. The email address you provide will be your new Apple ID as well as your iTunes Store account username. Tap Next.
  7. Tip: If you are trying to create an account using your MobileMe email address, you will receive a prompt telling you that your email address is already an Apple ID. Simply tap Continue, then tap Use Existing Account on the following screen.
  8. Next, you'll be required to enter your billing information. To change the default card type, tap the Credit Card field. Select your card type and tap Done. You will not be charged until you make a purchase.
  9. Once you've filled out all the fields for your billing information, tap Next to complete your account creation. ht3575-1.pngYou'll receive a notification that your account has been successfully created.
  10. Tap Done to go to the App Store or iTunes Store to begin browsing the store.
And there you Go.....
Apple iTunes | Answered on Jul 16, 2019
hi please help me itunse me is error 0x80092013 can u help me for problem ty my email: mohamad.emadodin@yahoo.com
most probable chances are that the disc has some minor scratches and you are using some delicate drives like sony... if you want to recover the data then use a samsung drive (small scratches are not a problem for that drive), then take a backup of your disc, i am not saying your drive is not good but this is what i have experianced..
Apple iTunes | Answered on May 22, 2019
1 - When viewing the apps on your iDevice in iTunes, you can check and uncheck apps from the Sync Apps list to add or remove them from your iDevice when you sync next. If there are apps listed that you know you'll never return to, you'll notice that there is no way to delete them from this list.
delete-apps-from-itunes-43svrqxrf5oj4k5lwwnp3neh-2-0.png 2 - A window will pop up, asking you if you are sure you want to delete the selected apps. If you are certain of your intentions, click the Delete Apps button.
delete-apps-from-itunes-43svrqxrf5oj4k5lwwnp3neh-2-2.png 3 - Next, to remove all files associated with the apps you selected for deletion, click Move to Trash on the next window.
Apple iTunes | Answered on May 14, 2019
Your library is held within your user files at user/music/iTunes. So as long as you don't delete that your library will be safe after uninstalling and re installing. Uninstalling does not itself delete that file or folder. :)
Apple iTunes | Answered on May 13, 2019
Hi, I have a suggestion for you just visit on this link and find apple customer service phone number and ask your problem about your Apple device may be this link is helpful for you please visit on this link https://bit.ly/2P5lXNm
Apple iTunes | Answered on Apr 30, 2019
If there are some duplicate songs in iTunes, you may listen to the same song for more than once. This is a bit annoying sometimes. In order to resolve how to delete duplicates in iTunes, you can read the contents shown below.
1. Run iTunes on computer and ensure it is the latest version. Click on the "Music" panel in the left sidebar. And then you need to tap the "View" button in the toolbar and then choose the option of "Show Duplicate Items" to click on.
2. The duplicate songs will shown in the right part of the interface. Choose the duplicate item that you want to remove from iTunes and right-click on it. After that, click on the "Delete" button in the menu.
3. Click on "Done" button after you delete the duplicate song.
You need to repeat the same deleting step until you remove all the duplicate songs. After you deal with how to delete duplicates in iTunes completely, you can listen to iTunes songs happily and at ease. There is no need for you to worry about listening to the same songs once and once again.
For more details, check: How to Delete Duplicate Songs in iTunes
how-to-delete-duplicate-songs-in-itunes-show-duplicate-songs-3-gwujvob1wsqcwi5j4bnkubbk-3-0.jpg
Apple iTunes | Answered on Apr 24, 2019
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
view-the-downloading-videos-by-sorting-16-1srvjsc4otpwize3cqbthuvm-1-0_4.jpg For more details, check: How to Delete Duplicate Songs
Apple iTunes | Answered on Apr 22, 2019
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use iTunes to move the recorded music from computer to your iPod
For more details, check: How to Download Music from YouTube to iPod
Apple iTunes | Answered on Apr 19, 2019
Movie from iTunes store has DRM copyright protection, you can only play it on your computer or Apple portable player. If you want to burn it to DVD to play on TV, you have to remove the DRM at first, and then convert and burn it to DVD. If you need detailed, I think this step by step guide would help you
http://www.freedvdripper.net/guides/burn-itunes-rentals-movie-to-dvd.html
Hope it helps. You can email me for further help.
Apple iTunes | Answered on Apr 10, 2019
HI,
Purchase Tunebite software. You may also download it, but will onlyreceive the first thirty seconds of video as a trial. Completeinstallation wizard, which can take several minutes.
Launch Tunebite software and click on the "Add" button. This process will allow you to load your iPodmag-glass_10x10.gif video library into Tunebite.
Click on "Convert Files" tab and place cursor over "Convert File to"drop down bar. Select WMV7 (1024kbps). Select "Start" to beginconversion process. The Digital Rights Management copyright is nowsuccessfully removed.
Download Aimersoft DVD Creator. Run and launch software. Simply click "Load Video" and drag videos onto storyboard.
Click "Burn". Select the "To DVD" option and adjust settings to NTSCfor television viewing. Insert a blank DVD-R/RW disc into DVDrecordable drive and record.
Tip
How to remove DRM protection from iTunes movie rentals to MP4
As most iTunes users know, iTunes not only allows users to purchase classic films or popular videos from its store but also provide rental service for the users. People are more likely to rent a movie than buy one, that means cost less.
However, low cost also has its drawbacks. Once you've started to watch the movie, you have 24 hours to finish watching the movie (even if you start watching before the download is complete). You can watch the movie as many times as you want within this 24-hour period. The rented movie will expire when either the 30 day or 24-hour limit is reached. Once the rental expires, the movie is automatically deleted. You must re-rent and download the movie to view it after your rented movie has expired.
So in order to keep iTunes movie rentals for long time with MP4 players while not online, the rented files needed to be converted with an appropriate program.
Instructions
  1. Download a converter program like M4V Converter Plus for Win. Install the program by double-clicking on the installation file after download. Finish the installation, click the icon and launch it.
  2. Click the Add Movies in top left corner, then you will see the pop up windows which will show you all the iTunes purchases and rentals. Find the file you want to convert and click OK button.
  3. The added movie rentals will show up on the main window. And then set the output as you need. Here we choose Same as source for MP4 from the output profile list.
  4. Click Convert button to start the iTunes movie rentals to MP4 conversion.
More info about M4V Converter Plus
M4V Converter Plus is an all-in-one DRM M4V removal tool for users which can not only get rid of DRM protection from iTunes movie rentals, but also convert them to various popular video formats like MP4, MOV, AVI, WMV, FLV and so on.
Both Windows version and Mac version of M4V Converter Plus are available for users.
Convert Any iTunes M4V to MOV
on Mar 27, 2019 | Apple iTunes
Apple iTunes Logo
1,437 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
error 3503
  • Computers & Internet
