20 Most Recent
Sony Ericsson W890i Cellular Phone Questions & Answers
Don't call anyone
try removing sim card...clean the card contacts and re-install power up
Reset
buy a better one, lol
I can't connect on facebook
Hello there,
Could you please tell me what is the error you are getting? Are you connecting via Wireless or GPRS?
Insert sim problem
First All Check:1.Confirm whether same sim card is working in other h.s or not.2.Make sure the sim slot is o.k. only try these two.3.If all the above steps fails, check the SIM card connector pins for damage.if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.u can make it jumper mean u can fix this prob with out sim card is for this contact.5.take sim connector slight up by pin then cheak by inserting sim.6.hot air gun on sim i.c. then cheak it.Last Option:IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service& Sim Office and Get the Duplicate Sim Same Your No From Office OpratorProblem will Solved Quickly
Lost contacts and don't see new call and messages
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
My sony ericsson w890i not power
Check the battery voltage, possible damage on the board. AlsoIt is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Sony ericsson w890 wifi not working
Check weather any other device can detect wifi signal of your modem router. If it cannot detect the signal then it may be the complaint of your modem roter wifi. If the other device can detect wifi of your modem router then back up the data of your phone and reset it. It will work fine.Thank you
