20 Most Recent
Samsung SGH-A747 Cellular Phone Questions & Answers
Need the unlock code and procedure for a Samsung
Get the unlock code here
mobile-unlocker.com and get the following instruction here
mobileunlockguide.comMethod 1:
1 - Switch ON your Samsung A747 with a
NOT ACCEPTED SIM
Card.
2 - Samsung A747 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung A747 shows "Insert Correct SIM Card")
Method 2:
NOT ACCEPTED SIM
Card.
2 - Don't bother about what's being displayed on your Samsung A747.
3 - Compose :
#0111*CODE#.
I want to lock my
The default code for samsung model is 00000000,it the code doesn't work,you need to reset phone by type this codes.
*2767*3855#
*2767*688#
*2767*2878#
Be sure to back up all necessary data before applying this method..
I hope this will help you.....
WHEN I CONNECT TO THE
its a simple phone setting that needs to be changed at your att (im assuming is your provider) store. they will set it right up for free! hope this helps let me know
Sound Ican hear them they can't hear me
Call your muted A747 from another phone.
Answer the call.
On your A747 select Options with the top left button.
Select the first entry, Mute/Unmute.
This fixed the same problem on my A747. Before doing this the Mute/Unmute had no effect. After doing the repair, all is OK.
How do you take the
A lot of sites do unlock but there is this site I used couple of times and it pays best since I've been unlocking phones.
You get full money back guarantee.
Visit http://www.mobileunlocked.com/index.php
and just follow the site prompt.
Good luck and remember to rate this solution
MY CELL PHONE --- ADD
Hello.
Please provide more info.
For your Samsung SGH-A747 (correct ?) what is it that you want to Add or Delete. Have you received any error message ? Any problems ?
My phone is freezing
First you have the heavy applications that are on the phone.
Then you can turn off the phone, remove the battery and reinstall it back.
If the fault persists, then you have to Flash the phone with the appropriate software and cable.
If it does not work,
Then you have to fix the flex of the phone.
Take care
