20 Most Recent
Samsung CLP 315 Laser Printer Questions & Answers
Replace/Install toner waste bin error
The toner box is probably full. The toner box is a clear box on the left side when you open the front cover. The box has the labels Y, M, C, and K on it. Pull it out using the tab at the bottom. find a place to empty it. You can do this by turning it upside down and gently tapping it. If the box is full some toner may be outside of the box causing the sensor to be blocked even after it is empty. You may want to clean the box, toner cartriges and inside the cavity with qtip, tissue paper (without lotion), or air.
Samsung clp 315 red light
The red light error can be caused by the following:
1. Paper is empty on the tray.
2. Access door panel is still opened.
3. Paper jam
4. Toner is empty
5. Broken parts inside the printer.
Try to check those things.
SAMSUNG CLP 315 paper jam
the printer may be detecting dust or something on the sensor, and detecting it as a jam
try to get the sensors cleaned, tell us how you go
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
TONER RESET PROCEDURE
No toner reset procedure , u need to replace toner chips ,else replace with oem toner cartrdiges
